Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire washer the washer doesn't fill up to the proper level to wash the clothes in my brand-new, super capacity, heavy duty washer. It is very annoying. A repairman came out to "fix" it, and it's even worse than before. What can I do?
  • Anonymous Oct 21, 2008
    the water level is low when washing the clothes, even if we put alot more clothes in its. please help.
  • 958 Answers
Hi mom,
could it be that these newer models now a days uses less water to wash clothes?
that is what they are boasting about.
energy efficient washing machines..less water more cleaning. ( at least that's what they say) specially on front loading types. not like the top loading where it uses a lot of water.
please check your owner's manual, it may be stated in there regarding water level of the new washer.
tnx 4 using fixya,
drcool
Posted on Sep 26, 2008
Cell phone gets hot
Probably due to lots of apps running in current and background sessions. Turn some of the unneeded apps off, and understand that as you use your phone the battery will become warm as it provides the current to the phone.
Mar 31, 2015 | Frigidaire FGX831FS Washer/Dryer Laundry...
The drum on my dryer seems to be stuck and is not spinning, the belt is on and seems to have the proper tension. Can someone help me get this dryer running again?
inspect the tumble dryer drum shaft - see image
inspect the dryer belt tensioner - see image listen for sound when electric motor is running
25302111-r0o5diaoq3uxmfwmdgmcujgm-1-0.jpeg 25302111-r0o5diaoq3uxmfwmdgmcujgm-1-2.jpg
Dec 01, 2014 | Frigidaire FGX831FS Washer/Dryer Laundry...
Heavy duty super capacity plus
Check water level switch and associated hose, see my other posts on this solution.
Aug 19, 2013 | Admiral AW22 Top Load Washer
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Roper heavy duty super capacity 8 cycle fabric softener mess
check to see when and where you are to add the softener read the manual for tips look in the trouble shooting guide
Jul 06, 2012 | Roper RAS8445KQ Top Load Washer
Whirlpool heavy duty super capacity plus LSR 7233 EZO
Most likely, the legs on the machine aren't level, causing it to move during operation.
Jun 12, 2012 | Frigidaire Washing Machines
Washer did not spin
JERRY,
IT SOUNDS LIKE YOU GOT TAKEN ON THIS WASHER. A NEW WASHER NORMALY WORKS, BUT IN SOME INSTANCES, LIKE YOUR CASE, IT COULD BE THE BELT OR THE MOTOR COUPLING. WHAT I WOULD DO IS CALL THE PLACE WHERE YOU GOT YOUR WASHER FROM AND HAVE THEM TO BRING YOU A NEW REPLACEMENT. THERE HAVE BEEN COMPLAINTS ABOUT WASHING MACHINES NOT WORKING RIGHT WHEN THEY WERE NEW. I HOPE THIS HELPS YOU AND ANYBODY ELSE WHO READS THIS WEBSIT, BECAUSE THERE IS NO SENSE IN THE STORE SELLING A BRAND NEW WASHER WHEN IT ALREADY LEAKS.
RODNEY
May 14, 2009 | Crosley CAWS729MQ 3.2 cu. ft. Washer
Please help...
when water is turned back on does it run in without turning machine on? if so fill valve is probably bad if overflowing and washer is cut off and water stops suspect water level control
Aug 12, 2008 | Frigidaire Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
95 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
