Question about Nikon D70 Body Only Digital Camera
Flash How do you turn the flash off on the Nikon d70?
  • 4 Answers
If you shoot in Auto mode, the camera will not allow you to turn off the flash when it senses that it is needed.
To use the camer without the flash, change the mode to Program ("P"). Once it's in P mode, the flash will not fire as long as it's in the down position. When you want to use the flash, press the speedlight release button (the one with the little lightning bolt near the mode select dial).
Posted on Oct 17, 2008
4 Suggested Answers
cammedic
  • 667 Answers
SOURCE: nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
Posted on Jan 10, 2008
  • 33 Answers
SOURCE: nikon d70 firmware version 2.0
From your question it isn't clear whether or not you are formatting the card in the camera.  Is this how you are formatting it?  If not, you should try doing just that.
Do not use a computer to format the cards for your camera.  In the future, use only the camera's own formatting and do it after every time you transfer your images to your computer.  In case you don't know how to format the card with the camera, let me know and I will explain it.
Posted on Feb 03, 2008
  • 291 Answers
SOURCE: I can't seem to turn the flash on my Nikon D70 on!
If nothing else it should pop up when you put the camera in A or M or S and then press the flash button on the side. It might or might not fire, depending on the light available, but it should for certain pop up. When you do this, you should hear a click and the flash should pop up. If you hear the click and it doesn't pop up, then it's jammed or glued or somehow being mechanically prevented from coming up.
In Auto modes, you can select the flash to off with the side button and the back rotary selector. This is where the flash symbol with the slash through it tells you the flash is off. If you push the flash button in Auto modes with the flash selected off, it won't pop up.
There are also some things the D70 can do to control external flash units that may be set abnormally.
The best way to make sure those aren't messing you up is to select "reset to default". That will take the camera back to a base setup that should work.
If none of these things gets it going, take it in to the Nikon dealer in town.
Posted on Sep 02, 2009
Is this flash to use on a nikon D70 camera. It works on a F70 but on a d70 its not functioning
The Achiever Flash 630AF is for Film Cameras and will not work properly on the Digital D70 camera.
Nov 29, 2010 | Achiever 630AF for Nikon TTL Flash
I cannot get my Nikon D70's flash to activate
I assume this is no longer an issue, given that more than a month has gone by without a response to my query.
Apr 07, 2010 | Nikon D70s Digital Camera
Sb600 flash has no communication with d70 camera
Have you tried using the wireless mode? Even if there is a problem with the hot shoe interface, it might still work using the wireless mode. To do this you have to set both the camera and the flash. On the D70, under the menu with the icon that looks like a pencil, select Flash Mode|Commander Mode|TTL|OK. On the flash, hold down the Zoom and [-] buttons to get the CSM menu. When you see the zigzag arrow, push the Mode button to turn on the wireless mode.You may have to use the [+] or [-] buttons to cycle through the menu to find the zigzag arrow.
Now you should be able to use the flash detached from the camera. Just pop up the D70 flash, which will tell the SB-600 what to do via light pulses. There are other settings that may be required (channel and group settings must match between camera and flash) and be careful not to block the light sensor on the side of the SB-600. If the wireless system is still working, you may find you like it better than hot shoe operation.
Dec 01, 2009 | Nikon Speedlight SB-600 TTL Flash
Metz flash 45 CT3 compatible with nikon D70
Call Nikon direct in Melville, NY or go to NIKONUSA.COM
Apr 20, 2009 | Cameras
Promaster 7500 D Digital Flash usage with Nikon D70
you need to go to your cameras menu and set your flash function to m ( no to ttl) set it in full M and then it works hope it works that works for me i had the same problem
Dec 05, 2008 | Promaster 7500DX for Nikon TTL Flash
Nikon D70 flah not working, used to
I had this problem a while back, but was fortunate to get it fixed under warantee as it was less than six months after Nikon repaired my D70 for the "blinking green light of death" fault.
I'm afraid this is a repair job for Nikon or an autorized workshop. It is most likley the flash tube. If you fancy taking your camera apart (I warn you it would be a fairly difficult job) then please be aware that you may get a significant electric shock from the flash capacitor, which will remain charged.
Feb 18, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon d70 flash stopped working
Well, you are not going to like my answer. The troubleshooting guide for the D70 says it could be 1 of several PCBs (printed circuit board) being faulty or the connecting FPCs (flexible printed circuit).
You'll need to locate a local repair person or use the reapir service search here on Fixya. Nikon USA repairs will be $$$$
Feb 15, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon D70 - indoor flash problems
Unfortunately, you may have a faulty flash pcb (printed circuit board) The part is around 50$ plus installation 200+ total repair cost. A work around would be to use an external flash unit from the hot shoe
Dec 26, 2007 | Nikon D70s Digital Camera
Nikon D70 flash doenot fire
Sep 21, 2007 | Nikon D70 Digital Camera
D70 digital camera
could be bent pin in the memory card slot
Jan 03, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon D70 Body Only Digital Camera Logo
156 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
