Question about SanDisk Sansa e200 MP3 Player
How do I erase the playlists on my sansa fuse 2gb player?
I have several playlist that got added to my player while downloading and I can't figure out how to delete them.
  • 65 Answers
Connect your mp3 player to your pc... find those unnecessary playlists and just delete them... if it doesnt get deleted then try to format the player and make it fresh... add playlists that u wish later :)
Posted on Sep 26, 2008
I have a Sansa e250 and I just bought a 8GB microSD card. Ideally, I would be able to add 10GB worth of music and playlists, however I can't get the Sansa player to read the music from the microSD...
The Sansa e250 works with microSD cards. Your 8GB card is actually a microSDHC card (the HC stands for High Capacity). While microSDHC cards fit into the slot, they are electronically incompatible and will not work in the e250.
microSD cards max out at 2GB in size, but you can put your music on several of them and swap them in and out. It's not as convenient as having them all on one card, but that's the best you can do with the e250.
Some later models such as the Fuze will accept microSDHC cards.
Aug 26, 2011 | SanDisk Sansa e250 MP3 Player
How to operate sansa and creating data base
Sansa support for e200 series:
http://www.sansa.com/support/sansa_e200/faqs
user manual e200
For making videos appropriate for your player use:
sansa media converter
When a total reinstall for the player is required perform:
sansa firmware updater
Remember: running a firmware update will erase all data on the player !
For transferring files from the computer towards the player you can use
Windows Media Player 11. A short guide in how to make transfers:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your data maps and ad files by drag and drop method
onto the right saying "Drag items here"
4. when ready adding files in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 installed with rockbox doesnt play video.
Sans e200 support:
Manual for Sansa e200 series:
http://www.sansa.com/sites/default/files/downloads/e200_userguide_en.pdf
1. Using the Sansa media converter for preparing videos to make them
suited for the player as you are doing is just fine.
2. Page 22 [19 in written manual] of the pdf file shows how to make playlist(s) using Windows Media Player 11.
2.1 First create a playlist
2.2 Save the playlist
2.3 Synchronize the required playlist onto the connected player
Sep 09, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e270 playlist in rockbox
all tracks will be in their proper folder, but as far playlist (that is winamp playlist) rockbox will create a playlist unless you change it .....
here read 4.4 of rockbox http://download.rockbox.org/manual/rockbox-sansae200/rockbox-buildch4.html#x7-650004.4
Mar 18, 2009 | SanDisk Sansa e270 MP3 Player
How to access SD micro card on sansa e250
I expected to find the new playlists on the SD card as a separate file to access and play. Instead the SD card songs show on up the Sansa menu simply added among the existing songs / artists stored in the Sansa. Its not a solution but they are there. Since using the SD card, my Sansa does databse refresh everytime it starts, whether SD card is in it or not.
Dec 18, 2008 | SanDisk Sansa e250 MP3 Player
Making playlists
yes you can create playlist using WMP11...
To create playlist using WMP
  1. 1. Click the Library tab. If you need to clear the List pane before beginning to create your playlist, click the Clear List pane button playing_i_clearlistpanebtn.gif.
  2. Drag items from the Details pane to the List pane to add them to the new playlist.
    To select multiple adjacent items, press and hold the SHIFT key while selecting. To select nonadjacent items, press and hold the CTRL key while selecting.
  3. To rearrange items, drag them up or down in the List pane.
  4. To save the list, click Save Playlist at the bottom of the List pane, and then type a name for the playlist.
    By default, playlists are saved with a .wpl extension in the Playlists folder, which is usually located in the Music folder. You can also save playlists with the .m3u or .asx extension. To do so, click the List button at the top of the List pane, click Save Playlist As, and then change the extension in the Save As dialog box. Once you save the playlist, it's added to the Playlists category in the library.
    To play the playlist in the List pane, click the Play button playing_i_playbtn.gif.
  5. To access the playlist in the future, click the Playlists view in the Navigation pane.
I hope that helps
Please rate accordingly
Thank you
Computerrep
Jul 19, 2008 | SanDisk Sansa Connect MP3 Player
Playlists on the MicroSD card?
You just reminded me. I took my SD card out and put it into my phone. I'll replace it in the Sansa and see what happens. So far, synching with WMP works, but still not Napster (where I do all my purchases). oh well.
I'll try putting my card back in. Maybe a DMR key was on it. Also, I may have changed the name of my player. Lookign into a couple options. Back later/another day.
Feb 12, 2008 | SanDisk Sansa e260 MP3 Player
Can't add playlists
go to computer than click on Sansa e260
- Click on PPI NAND
- Click on PLAYLISTS
- Create a new FOLDER
- Give your playlist a name
- than put the music in it.
Nov 29, 2007 | SanDisk Sansa e260 MP3 Player
Sync to player and memory card without duplicates
I got this from:http://www.livedigitally.com/2005/06/27/sandisk-sansa-e130-the-micro-version-of-the-ipod-mini/ Create two playlists with names such as 1. SANSA Internal and 2. SANSA 2GB (assuming your SD card is 2gb). Load songs into each playlist. Edit the sync properties for each drive to only sycn to those playlists. Sync!
Feb 08, 2007 | SanDisk Sansa e130 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
173 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
