Question about Philips 9P6444C 64" Rear Projection Television
Just got a broken TV
Hey ive taken the back cover off and the red bulb seems to be blown as their is liquid where the others do not have liquid.. when i turn it on it powers on but the projectors do not come on the sound is working as when i unplug it i can hear the back feed hit the speakers any way i can get a manual to test the circut board out to make sure its only the one projector? and if i replace the red projector bulb will the others come on or shouldnt just the red be out and the others still work im more of a computer geek than a tv repair man please help
  • 85 Answers
Man you may have a big mess on your hands the cooling fluid has probably gotten on a circuit board(s) and ruined it them and using the set with a cooling fluid leak is dangerous. You may need to replace the small signal board large signal board and the cooling fluid in the crt. I suggest this job to a pro
Posted on Sep 26, 2008
I have a Sony KDF-E55A20. I just replaced the bulb, the old bulb was broken. I replaced the bulb but the TV still does not work. There's a series of 3 blinking red light. What does this mean? After I put...
Put lamp cover back on tv as it will push a safety switch inside then tv will turn On.
Lamp cover is first thing that you removed to replace lamp in tv.
Hope this will help you.
Thanks.
Nov 17, 2010 | Sony KDF-E55A20 55 in. LCD Television
Tv will not turn on blinking als red light
the answer for this problem happens to be a blown projector or broken projector bulb it needs to be taken to a shop and be replaced
Dec 12, 2009 | Toshiba 50HX81 50" Rear Projection...
Sagem Axium HD-D45 S G4.T/2 of (HDD-D45F) range.from standby lights go red/ orange flashing, then the fan should start up and t.v picture appears. The fan does not start up and no t,v picture and the set...
Sagem Axium HD-D45 S G4.T/2 of (HDD-D45F) range.from standby lights go red/ orange flashing, then the fan should start up and t.v picture appears. The fan does not start up and no t,v picture and the set reverts back to standby
Aug 04, 2009 | Sagem Televison & Video
Need to replace lamp cant figure out how to take out
on the front of tv set there is a panel that you unscrew to get to the lamp then once you get that done you have to go through the back of tv to remove and yes you can buy the bulb by itself but you have to order it or any tv repair place might have one in stock
May 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Blackberry pearl wont stay on and red LED light keeps flashing
my phone wont stay on and when it does come back on it shuts right back off. the LED light on the front keeps flashing red. ive taken the battery out and everything and nothing seems to work. help please!
Apr 07, 2009 | RIM BlackBerry Pearl 8100
Clutch csae weaping
A issue with the 99~02's is that the clutch cover gets warped from the repeated heat/cool cycle associated with riding your bike. You can take some 500 or higher grit sand paper and tape it to a flat surface and then in a cicrle pattern smooth the clutch cover out. Works for some people...if it's too far out, you'll have to get a new cover.
Nov 20, 2008 | 2007 Suzuki SV 400 S
My television
depending on what kind of TV it Is, If Its HD or like the Flat Kind My Solution wount help, because i've never took one apart before. if its a big bulcky kind take the screws off an an take the back cover off, but be sure to be carfull with the lil glass bulb located on the back of the screen it holds a chemical in it, an tv wount work, once taken off you could either replace the blown speaker, or just run a speaker wire from the wire connected to the blown speaker an run it out the vents on the TV an find any speaker not with too many watts, ive hooked up 2 150 watt speakers to mine an it worked fine i hade the same prob. another thing, if your warrenty is stil good you could get a replacment
Oct 18, 2008 | Scott SQX-900F Main / Stereo Speaker
Blown bulb
time to change the bulb, the bulb doesen't last very long for the price that it cost. I have replaced three in mine in the past three years.
Jul 04, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Sony 62" Grand Vega HD TV
JUST BECAUSE THE BULD NOT BLOWN DOSENT MEAN THAT IS GOOD I HAVE 40 OR SO BAD BULBS AN HALF THEM ARE BOT BLOWN HAVE A SERVICER TEST IT AN THEIR IS A TRIP SWITCH ON THE OUTER COVER THAT TELLS THE TV IF THAT COVER IS OFF OR ON WILL NOT START IT THINKS IT IS OFF
Mar 30, 2008 | Sony KDF-42WE655 Television
Philips 9P6444C 64" Rear Projection Television Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
