Question about Panasonic WORKiO DP-1520P All-In-One Laser Printer
Unable to get my Windows 2003 SB server to see Dp-1520P
I have a known good ethernet connection. NIC has link light and flahing data light, so acts as if it is on netowork. My server does not see the printer and I can not install it.
    Sergeant:
  • 284 Answers
Here are all the latest drivers
http://panasonic.co.jp/pcc/products/en/mfp/download/index.html#DP-1820
can you ping the machine.
do you have a proper ip, subnet mask, gateway,
what happens if you use a cross over cable to connect to it.
Posted on Oct 01, 2008
Panasonic 1520dp
please help me how to fix my PANASONIC DP-1520p printer, it always getting OFFLINE in my computer, it connects in ROUTER thru broadband. but it works fine in other computer. i tried to fix the connection many times. but it seems that all the wire are fine. pls. help me what else i need to do. tnx!
Jan 24, 2012 | Panasonic WORKiO DP-1520P All-In-One Laser...
I have Dlink DP-300U print server which has ip address of 192.168.2.150 but i want to change into 10.xxx.xx.xxx ip range how can do? i tried by changing the ip address of the pc to Dlink switch range but...
Ideally, you change your PC's NIC to an IP in the range of 192.168.2.150, say 192.168.2.2 with mask 255.255.255.0 then directly connect your NIC to the Print Server and open your browser to 192.168.2.150, from there change the IP address of the Print Server.
Jun 25, 2011 | D-Link DP 300U (DP-300U) Print Server
Fujitsu Siemens GA-8ISXT-FS, can I add a 2nd ethernet card / NIC
The P/N GA-BISXT-FS is a Gigabyte mother board which has 5 availble PCI slots.
If you don't see any open slots, chances are that all 5 of the slots are already in use.
Take a look and maybe you can pull out of the cards you don't need and install the 2nd NIC card.
Good Luck and let us know how it works.
May 26, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
How do i get the phone line connected to recieve a fax
There should be two sockets on the back of the printer that handle phone lines and one that handles ethernet. The socket that receives the fax signal with be marked "Line" and the socket that connects to a separate phone will be marked "phone". Since most faxes only use two wires for communication, sometimes there is a fax adapter wire that some manufactures include with thier systems, it is not always needed but it acts as a good filter.
Aug 31, 2009 | Panasonic WORKiO DP-1520P All-In-One Laser...
I connected an ethernet cable to the DES-1024D switch, but the link/act LED didn't light
Is the switch powered up?
is the Ethernet cable connected to a working/powered/enabled NIC?
Jun 10, 2009 | D-Link DES-1024D Express EtherNetwork...
Driver for DP 8016p for Vista
i wont driver for DP 8016p for windows7
Mar 20, 2009 | Panasonic Workio DP-1820P Laser Printer
DP-301P+ Express EtherNetworkTM Fast Ethernet Print Server
You need to connect to it (using the broswer at the PC of same LAN with the current ip of the print server). Then click on Tools TAB, click on "Reset" at left. You should see "Do you want to restore this device to factory default setting?". Click on "Apply"
Jun 04, 2008 | D-Link DP 301P (DP-301P) Print Server
Panasonic WORKiO DP-1520P All-In-One Laser Printer Logo
104 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
