Motherboard issues Hello What is the part number for the motherboard installed in a Presario 3417 laptop? The only thing the laptop does is to turn on the power and the energy leds but doesn´t start the hard drive on the machine (screen remains black) and after five minutes or so without any change on the screen the notebook simply turns it off by itself, someone told me that it could be the motherboard. I hope you can help me
  • 171 Answers
If you have an external monitor available, connect your laptop to it and start the machine. It would not start and shutoff if the motherboard was failing. It would not power at all or would turn on a display an error, with some beeps. By plugging into the ext monitor, you can amke sure this is not a video problem and watch it boot, until it gets to the error, which is probably a Windows Blue Screen.
Posted on Sep 26, 2008
Hd sound card compaq presario c700
Hello you can find the driver here:
http://www8.hp.com/us/en/support-drivers.html
By entering the full model number.
The number is placed under the pc.
When you find your pc, you might have to select your windows system.
In order to find the right driver.
HP owns compaq, and this is why you have to seach for drivers at this site.
Good luck
Jan 08, 2013 | Compaq Presario C700 Series Laptop...
I want toinstall compaq pressiero c700 latop audiodriver
Hello download the driver here:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=3466274
Please select the id number.
The number is placed under the pc on a sticker.
Or find the pc automatic:
By installing a small program.
Good luck
Nov 29, 2012 | Compaq Presario C700 Series Laptop...
I have a presario CQ 61....when I turn it on I get a black screen and the only thing that it does is the cap and number lock blink twice in a row..
in my experience this means the motherboard is bad. if the laptop is under warranty you'll have to call HP for support. if the laptop is out of warranty, the motherboard is usually expensive enough ($200-$300 or more plus labor) that it would be more cost effective to just buy a new laptop. your data should still be on the hard drive.
800-474-6836 hp support
May 03, 2011 | Compaq Presario Notebook
Compaq presario v2000 graphic card issue
You must get in touch with HP and check you are using the correct driver or the latest version. If not then perhaps there is an issue with the driver file and you can download it again.
May 17, 2009 | Compaq Presario Notebook
Hello.. there is no light when i press the Numlock even if i press Fn+Numlck... only the Numbers are functioning.. but not the characters above the numbers.. unless you press shift.. tnx.. more power..
I think one of the first things you should attempt to do is ground the motherboard. I have been having several issues with my dell studio 15 and what I initially believed was it was a result of installing the latest vista service pack. I have since begun to believe the issue is deeper than one of software.
To ground the motherboard, perform the following steps:
1. Remove the power supply from both the laptop.
2. Remove the batter from the laptop
3. Open (lift the screen) of the laptop (with the power and battery removed) and press the power key as if you are attempting to turn the machine on. (this ensures that all power that may have been within any particular component will flow through the system and reach ground).
4. Plug the power and battery back in and turn on the PC.
See if those lights on the keyboard and top functional lights begin to work. This has worked for me, but I have not been able to get a good answer to what causes this.
Apr 20, 2009 | Dell Studio 15 Laptop
Uninstall
Well yes and no. I believe you're asking if you can remove vista to install xp? It is possible to do so however HP/Compaq use a proprietary software to "tattoo" the motherboard which designates the unit as either a Vista computer or Other OS computer. Though it is possible to install and run XP on a Vista machine, complications may arise causing things like the OS to not properly validate and other software related issues.
Nov 25, 2008 | Compaq Presario Notebook
How to re-install Bios
hello bhargav....
To make BIOS to default.... you have to do a jumper setting.... on motherboard
or based on the model number of the motherboard... download updated bios.. and copy it into the Floppy/CD... and try installing it... going to bios and choosing update bios option..
Nov 07, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario v2000 amd turion64
question.....does the motherboard you use support the powersource? that is one thing i would look into and have had problems with with many pc,laptops,etc. lemme know what happens
Aug 05, 2008 | HP Compaq Presario V2000 Notebook
No sound can
hello. sir. i have lost sound from my lap top Compaq presario C700 after installing windows XP. kindly help me. my laptop is also showing pproblem during installation of hard drive for same driver, every time i turn on my laptop. i donot have the installation mother board for the same laptop
Jul 13, 2008 | Compaq Ensoniq AudioPCI Sound Card
Computers & Internet Logo
393 people viewed this question
David Payne
David Payne
