Machine Error 71, Brother MFC 8440
What the heck is Machine Error 71 on a Brother MFC 8440?
  • Anonymous Mar 19, 2014
    ERR 1; 48 MFC J220 BROTHER
  • 37 Answers
The problem is in the scanner motor.To cancel the trouble status follows these steps:
STEP1 .Press MENU *,2,8,6,4
STEP2.The machine beeps for approx. one second and displays “MAINTENANCE" on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
the machine is ready to accept entry from the keys.
STEP3.Now you are inside the simulation Press 01 to reset the trouble status.
STEP4.To exit the simulation press 99
Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine
exit from the maintenance mode, restoring it to the standby state.
Pressing the Stop button after entering only one digit restores the machine to the initial
stage of the maintenance mode.
I hope that this will cancel the error but if not canceled you should call the authorized serviceman to fix your machine.
Posted on Mar 01, 2009
MACHINE ERROR CODE 6B ON BROTHER MFC-8440 ?
A6 error means the CIS unit is defective and needs to be replaced.
Unfortunately this can sometimes cost more to replace then the machine itself
Thank you
Regards,
Suhail
May 16, 2012 | Brother MFC-8440 All-In-One Laser Printer
WHEN I TURN ON MY MACHINE BROTHER MFC 8440 I SEE ON THE SCREEN ERROR MACHINE 6A I NEED A SOLUTION
Error factor: Heater warming-up timeout error.
(Heater does not reach 60°C within 11 sec.)
Check: • Thermistor ASSY
• Halogen lamp
Jan 08, 2011 | Brother MFC-8440 All-In-One Laser Printer
Machine error 6F on a brother mfc-8440 how can I fix this. I need to print bad
this could be either the thermal fuse on the machine or the power suply. it means that the fuser on the machine is not heating up. this error would need servicing on the machine unfortunatly
Mar 31, 2010 | Brother MFC-8440 All-In-One Laser Printer
Error message 71
This error means that there is a scanner motor error. Try and remove the error by following these steps: Press MENU *,2,8,6,4. The machine beeps for approximately 1 second and will display "MAINTENANCE" on the screen, indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys. Now you are inside the simulation, Press 01 to reset the error status. After that press 99 to exit the simulation.
- Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine exit from the maintenance mode, restoring it to the standby state.
- Pressing the Stop button after entering only one digit restores the machine to the initial stage of the maintenance mode.
If the error comes back call Brother support, here are the contact details:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
Phone: 1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
Monday-Friday, 9:00am to 8:00pm Eastern Time
Feb 14, 2010 | Brother MFC 8440 All-In-One Laser Printer
Machine error code 6A what that means?( Brother mfc 8440)
I argued on the phone with a BROTHER REP. that he should give the codes and directions to reset the machine, he refused time and time again, saying that this means physical damage to the machine an re-setting it is impossible to help, but i insisted, and it did fix the problem and the error went away.
here is what you should do, unplug for 10 sec. press and hold on the menu key while you plug it back in untill you see the screen "parameter init" press 99 and wait, this is what i did and it fixed the problem !!
Jan 26, 2010 | Brother MFC-8440 All-In-One Laser Printer
Machine erro 71 new scanner moter still giving me erro 71???
sometimes people use different names for these two items, but "scanner" to me as a tech, is the assembly with the light under the glass. the error 71 points to your "laser" unit which is pretty deep inside your machine and most likely, only a tech would be able to replace it. once replaced, the code will automatically reset.
hth,
razors
Mar 12, 2009 | Brother MFC-8440 All-In-One Laser Printer
first what is the message???? i will try and help you whenn you let me know the problem or the error message
Dec 10, 2008 | Brother MFC-8440 All-In-One Laser Printer
3,528 people viewed this question
jasbo
jasbo
