Question about Motorola Mobility RAZR V3
Motorola Razr Backlight
My Motorola Razr's backlight won't go off. Can someone help me?
    Brigadier General:
  • 7,752 Answers
Try a master reset if that does not work then the phone needs to be check by a professional mobile tech to determined the problem and correct it.
Posted on Oct 05, 2008
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
Buzzing at my cell phone near the flexible
remove the battery... and dont return it so that the buzzing wont come back....
Feb 27, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Screen
menu/settings/initial setup/backlight or display
Aug 18, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Backlight stays on...
i believe u should reset ur razr. it could help
Jul 10, 2008 | Motorola Mobility RAZR V3
Razr phone backlight stays on while charging
hi,
  dis is common in razr and samsung higher models...d backilight ll glow when u put d mobile on charge...i have a samsung d840 metallic series phone, d backlight glows througout d charging period..my friend has a razr and in tat also it glows when it is charged...so its common in razr and samsung..nothin harm to d mobile because of this....
good luck
Jul 04, 2008 | Motorola Mobility RAZR V3
Backlight display not working
Hey Dannes1956,
The Motorola V3m has a light sensor, which is visible just above the right soft key -- the key above the CLR button. This light sensor turns the backlight on when you press a key in the dark and disables the keypad backlight when you are in a well-lit area.
Your phone sounds like it's operating normally. I believe they disabled the option to activate or deactivate that feature.
Hope this helps,
cHiPz.
Mar 17, 2008 | Motorola Mobility RAZR V3
Backlight problem
exchange the phone for a new one.........see if that corrects the issue
Mar 14, 2008 | Motorola Mobility RAZR V3
Broken backlight
if you open the v3 phone flip...you shall see 4 rubbers...remove the rubbers with a very small flat bit screw driver then unscrew the 4 screws in the phone then use the small flat bit onc more to open the phone cover, then remove the silver button on each side of the phone, unclip the cable leading to the camera and also the clip connecting to the lcd once those are removed then replace the old screen with the new one.
Dec 22, 2007 | Motorola Mobility RAZR V3
Broken backlight
  • Just get a new one
  • Buy one and replace it
  • Cry and ask your parents for a new one
  • Ask a fairy to fix it or Santa Claus
Oct 19, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Razr has no backlight
that happened to me too but i didnt get mine wet, it did the same as yours though my dad took out the battery for a while and then put it back in and it was fine! :) goodluck! only now it wont turn on! lol but it isnt from that.
Nov 27, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
83 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
