Question about HP LaserJet 2200D Printer
Paper Drawer Problem
Somewhat frequently the printer won't print and I've found that the solution is to re-adjust the tab in the back of the paper drawer so that it is pressed all the way up against the paper. But I'm having to do this sometimes several times a day. Any suggestions on a fix?!
  • 72 Answers
You may need to get a new paper tray.
Posted on Jan 16, 2009
Dell 1720 printer single-sheet feed stopped working
Pull out the paper that is jammed and continue.
Nov 29, 2012 | Office Equipment & Supplies
Lexmark officeedge pro550 print drawer won't close with legal size paper in it
That's normal. If you extended the tray to accommodate legal-size paper, then the tray sticks out from the front of the printer when inserted.
Aug 24, 2012 | Lexmark OfficeEdge Pro5500 - multifunction...
My printer won't print letter automatically. It's stuck on printing only legal. If I pull legal tray out it will print letter. But I need it to adjust with alternating print jobs.
Printer wont stop paper, if any page length mismatch,Select page length as any size, as well as while shooting the print command select page length as legal & try it. I feel that teflon not rotating properly, result paper jamming at bottom end. If any paper length faulty printer detects the length give message of mis match..Pl check carefully...
Feb 01, 2012 | HP Laserjet M2727nf Multifunction Printer
Black ink won't print and I just changed the ink
Try using the photo paper option instead of the plain paper option.
I was using plain paper but, selecting the plain paper option...I could barely read the print. The photo paper option worked great!
Hope it helps!
Nov 14, 2011 | Brother MFC 6490CW InkJet Printer
Everytime I send something to print the printer starts normally, it grabs the paper to start printing but then the paper never moves again. It sounds as though the document is actually printing but theres...
I don't know what printer you have, but this applies to all printers. The first paragraph is just for inkjets. The the whole is related to laser printers.
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Jul 15, 2011 | Office Equipment & Supplies
Paper
If the paper size tab inside the drawer is out of position, even by 1/8 inch, you will have this problem. Also, the drawer itself could have a flaky/broken paper indicator switch (shows how much paper is left). I have had both these issues. On the first, I just slid the adjuster back in to letter position. The second, however, took replacing the drawer.
Nov 18, 2008 | Brother HL 5140 Laser Printer
Will not print in color
Good Evening Richareelita:
Hope that you are wellJ
These are the solutions that I found for you. Personally, I think that you need to update your drivers, but wanted to offer you more than one solution.
Adjust printer settings
Click Start , click Settings, and then click Printers.
Right-click the icon (picture) of the printer.
Click Properties .
In the Properties dialog box, click the Details tab.
Look for the text Print using the following driver .
Under Print using the following driver , verify that the name of the printer is listed.
Click the Color or Color Management tab.
Click Automatic .
Click the Setup tab. If you do not see a Setup tab, click the Device Options tab. If you do not see a Device Options tab, click the Details tab, and then click the Setup button.
Locate the text Print Quality .
For Print Quality, choose Best or Presentation .
Look for the text Paper Type , Media , or Media Choice . If you do not see any of these options, click the Paper tab.
Click in the box under Paper Type , Media , or Media Choice .
In the list that pops up, choose the type of paper or film you are using.
Under Photo Paper printing , choose PhotoREt .
PhotoREt is available only if you have chosen HP brand paper under Paper Type. If you don't have a PhotoREt option, look for the text ICM . If you see ICM , click in its checkbox to add a checkmark, and click OK .
If you see a tab called Advanced , look for text Saturation , Brightness , and Color Tone .
Move the sliders next to Saturation , Brightness , and Color Tone to adjust these settings. If you cannot find these settings, click the Graphics tab and then click the Color button. Choose the options that match the type of document you are printing.
Click OK .
Close the Printers window.
Open the software application that you were using to print.
Try printing.
If this does not work, try updating your drivers or uninstalling and reinstalling your printer software.
If I can be of further assistance, please let me know.
And, remember, always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful evening.
Sep 30, 2008 | HP Office Equipment & Supplies
My printer jams frequently
More info is needed where does it jam ie. going to print from paper tray or coming out of the fuser in back before it comes out on top?
Feb 26, 2008 | Lexmark E330 Laser Printer
Lexmark 642 printer on network will not print to tray three. When anything is sent to tray 3 it goes to tray 2 even though we set it up in our application to trigger $C(27)_?&15H?
I have found that if the print job needs a certain paper size and the tray is reporting a different size loaded into it then the job will pull from the next tray with an acceptable size. Lexmark's paper stops in the trays are easily moved by the wieght of paper loaded in it. If the job requires "Letter" checnk the size tabs on the left side of the tray, they are on the outside of the tray. For "Letter" just the buttom 2 tabs should be sticking out, adjust the green back stop until just the bottom 2 tabs are sticking out and try your print job again.
Jan 22, 2008 | Lexmark T642 Laser Printer
HP LaserJet 2200D Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
