Question about Whirlpool Kitchen Ranges
Whirlpool range Mod # YGY396LXPQ, oven has quit working. error Code E0 F-2 is shown on the keypad momentarily and then the screen goes blank. Ramge top still works fine.........Sheldon
5 Suggested Answers
  • 76 Answers
SOURCE: oven and keypad will not work.
longtallez The first thing I would recommend you to do is to reset the power. Locate the circuit breaker for the range and turn it off, wait a few minutes and turn it back on. It works the same way like you reboot you PC when it gets stocked. Let me know if it would not help and we will go further. Gendos...post back
Posted on Jan 17, 2007
SOURCE: my kenmore elite electric slide
Need the model number (specifically the 1st 3 digits ) too determine who manufactured it for Sears then can tell what the fault code means for that brand. You might try shutting the breaker off 20-30 mins see if it resets itself.
Posted on Jul 09, 2008
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
  • 3 Answers
SOURCE: Oven wont light
Mine did that and I found the ignitor for the oven was bad. It was the "glow" type for pilotless ignition and it was burned out. It is supposed to glow bright red and the gas comes on and the oven will light. It was easy to tell that it was bad. But to check it I swapped the broiler ignitor with the oven ignitor and the oven worked.
Posted on Dec 20, 2008
rockitman187
  • 2559 Answers
SOURCE: I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Posted on Jan 13, 2009
Whirlpool electric. range rbd305 oven went dead
quite often that's when the elements give out due to power usage of cleaning .
Apr 24, 2015 | Whirlpool Kitchen Ranges
I keep getting the following error message: E6 F2 - what does this mean?
If you have a Whirlpool oven, the F2 E6 error means that the Cancel key line is open. You will need to replace the keypad or the keypad and controller board (if a single assembly) if the keypad doesn't respond to a press of the Cancel Key.
I hope this helps.
Dec 12, 2011 | Whirlpool Ovens
After cooking my whirlpool Electric Range started to beep and shows EO F2. The range top is working ( and range top controls ) but the oven won't shut off and the controls are not working for the oven.
Here is what my online service manual for the F2-EO error code says
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock)
I hope this helps
Gene
Aug 01, 2011 | Whirlpool Kitchen Ranges
I am getting E0 -F2- error on my Whirlpool Gold Accubake oven display. If I press cancel it sometimes will start but has been working less and less. The range is quite old and I do not have a manual. What...
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Mar 29, 2011 | Whirlpool Accubake RF362LXTT Electric...
WHIRLPOOL GOLD DOUBLE OVEN BEEPING WILL GO BLANK THEN WILL SHOW E6 F2 TROUBLE CODE
Hi dear.Please do the following if you know what you are doing.According to your explanation,F2E6 code on whirlpool oven related with following: F2 - E6
Cancel key drive line open
I hope that solves your issue.Thanks.
Aug 28, 2010 | Whirlpool GBD307PDS Electric Double Oven
Error code EO -F2- Any one know what this means
Hello,means shorted keypad and need to replace the electronic range control/clock
Thanks
May 29, 2010 | Whirlpool RBS275PD Electric Single Oven
F2 code on my whirlpool stove buttons not working.
The F2 could mean a timer/control has detected a stuck/shorted keypad. Depending on the model number though it could also mean a shorted oven temperature sensor.
In the event it is a stuck keypad detected, the timer or keypad will need to be replaced. You should first attempt to reset the breaker or unplug the range for a couple of minutes to see if that resolves the error code.
If it is the model that uses F2 as the shorted sensor code, you`ll need to replace the oven sensor, there`s no way around that one.
If you can provide a model number by replying to this post I could try and be more specific, as right now I can only generalize with the most common F2 error codes meaning for Whirlpool manufactured ranges/ovens.
Hope that help`s, let me know.
Good luck.
macmarkus :)
Dec 06, 2009 | Whirlpool 30" Freestanding Gas Range -...
I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights...
Your error code is for a stuck keypad. You can try pressing every button at random several times each to unstick.'
When the control board is changed on these ovens the keypad assembly is supposed to be changed also.
Nov 21, 2009 | Whirlpool Ovens
Whirlpool RBD305PD has error F2E6 error on control panel
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
Apr 02, 2009 | Whirlpool RBD305PD Electric Double Oven
Or
Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
Kitchen Ranges Logo
56 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
