Question about RCA Televison & Video
Recentlygot a DTA800B1 converter it was my understanding that they would work with any type of tv antenna??? cannot receive a signal and the old anaalog works perfect
  • 85 Answers
It probably is working most of the new digital and HD over the air is broadcast in UHF band which is shorter range. Some people in my area cannot get a lot of digital staions whaic are the same stations in analog after installing their new convertor box. I suggest if you can get cable or satilite even a new set which a built in digital tuner may not receive anything over the air in certain areas Hate to tell you that but it is true
Posted on Sep 26, 2008
Want to convert analogue tv to digital
You need a digital converter to receive digital signals on an analogue TV (old type). If you are using an outside antenna you can purchase the box from places like Walmart, Kmart, Radio Shack for around $40. If you have cable TV or Sat (Dish or Direct TV) you need one of their boxes to convert the signal back to analogue. The Walmart type boxes WILL NOT WORK for cable or Sat TV.
Mar 30, 2015 | Refrigerators
Input signal.
You should be able to connect the TV to the antenna without the tuner converter box. If you still do not get signal you may need some type of signal amplifier between the antenna and TV. Hope that helps.
Dec 08, 2013 | Zenith Dtt901 Digital Tv Tuner Converter...
"How do I get this to receive free HD antenna TV?
You will need a antenna and a digital converter box to convert digital to an analog signal the TV can understand.
Oct 20, 2012 | RCA F27440 27" TV
Tried to hook up a HD antenna but it won't work
HD is pretty critical and if a indoor antenna do not expect much or anything for that matter.
Jun 17, 2012 | Televison & Video
We are in Ghana we need frequency and we update to get more channel
Your flat panel TV is probably factory set to receive ATSC signals (Hi-def DIGITAL TV), whereas
Ghana may not have converted from analog TV (NTSC) yet.
Digital TV's cannot receive analog signals. I'm just guessing about whether or not Ghana supports
Hi-Def broadcasts - you'll have to check with (any) TV channel in Ghana. The Analog-to-digital
conversion is an expensive one at the broadcast end, and may not have happened yet in Ghana.
The US conversion took place by FCC mandate June 12, 2009.
There are available $65 (USD) digital-to-analog converters, but what you may need is an
analog-to-digital converter, which doesn't exist. Your Flat-panel TV amy have to wait until Ghana
begins broadcasting a Hi-Def TV channel.
For a HD antenna, a regular old rabbit ear-type antenna will do.
Oct 15, 2010 | Televison & Video
DO I NEED A DIGITAL CONVERTER TO OPERATE A 4 YEAR OLD JVC MODEL AV-32D305 WITH AN ANTENNA?
If you have cable running to your house, cable still uses RF and older TVs work fine. The problem comes when you try to grab stations from the air. The signal is still UHF, but the information riding on that UHF signal is digital, and will need a converter box to turn it back to analog so your older TV will understand it. . Cable: None needed. . Antenna: Need a box.
Nov 25, 2009 | JVC AV-32D305 32" TV
Can not get all my local channels
May Be becouse Antenna On Top Of Roof Is to old, Plugging cord in wrong place plug in: In
Mar 25, 2009 | Curtis-Mathis CM19011 TV
Insignia Digital to analog converter menu doesn't come up
When my Menu did not come up, I found it on the AUX channel (one below channel 3). I was able to go through the set up, but found only one digital channel available. Hope this helps!
Nov 10, 2008 | Televison & Video
No antenna reception with digital converter box.
Hello Faznmc,
I have found that with an ordinary antenna connected to the converter box it can receive nearly all channels, however I have run into cases where I had to use an amplified TV antenna to pick up signals. I have started telling folks that when they install their converter boxes to try to use the plain old rabbit ears antenna, but if that does not work, use an amplified antenna, and that usually does the trick.
I hope this helps
Thank you,
Shuttle83
Nov 02, 2008 | Televison & Video
Hdtv converter box to vcr
Hi Drtrippy,
If I understand correctly, you are using your VCR for the actual tuning of the TV.
The converter box itself contains a tuner, so you should now receive extra channels available only to an HD tuner. You should try connecting your antenna as input to the converter box. Then output the signal from your converter box to the VCR. Your VCR may then remain connected to your projector.
You may simply think of this as if you are inserting the converter box between your antenna and your VCR, which should be currently connected to receive an over-the-air signal. Remember, as the tuner you will be using is in the converter box, you will need to change channels using the converter box, not the VCR.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 25, 2008 | Televison & Video
Televison & Video Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
