Question about HP LaserJet 3030 All-In-One Printer
Did you vote the solution correctly ?
You can contact me here if you get more problem with your printer or anything else with computers :P :)
Thanks ever so much for all your help! I have posted FIXYA's name to an international listserve of over 2300 hospitality industry professionals!
Sue
Posted on Oct 08, 2008
New computer lost printer disc can't download to new computer where can i get a startup disc so i can still use my printer
Your User Guide and drivers are available here:
http://support.en.kodak.com/app/answers/detail/a_id/19191/~/kodak-esp-5-all-in-one-printer%E2%A0%E2%80%94%E2%A0user-guide
Suggest you access the internet and download to a USB jumpdrive from which you can install on your computer.
If you must have the install disc, contact Kodak via their website to see if they are able to provide.
Trust this is helpful. Please vote.
Dec 12, 2010 | Kodak ESP 5 Printer
WHEN TRYING TO PRINT THE MESSAGE COMES UP THAT THE INK CARTRIDGE IS INCORRECT... AND WILL NOT PRINT. SAME CARTRIDGE FOR THE PAST 5 YEARS.. ?? MAC COMPUTER.
Either catridge is deffect, or contacts are dirty; using a lint free damped cloth clean contacts on both cartridge and cartridge holder.
pls. vote for better service... thanks.
Nov 13, 2010 | HP PSC 1210 All-In-One InkJet Printer
Page isnt prining out Have new ink in printer
Before you can troubleshoot the problem, determine its cause. Do the following steps in order:
1. Print another PDF, such as the first page of Acrobat Help.
  • If a separate PDF file prints correctly, the PDF that doesn't print correctly could be damaged. See "Can't print a specific PDF file" later in this document.
  • If the separate file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a plain text file) from another application (such as Microsoft Word or WordPad).
  • If that other type of file prints correctly, the problem isn't system-wide--it's specific to the Adobe Reader or Acrobat product. However, the problem could come from Reader or Acrobat interacts with the system. Go to step 3 to eliminate some system-related causes of the problem.
  • If that other type of file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDFs. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF.
  • If the file prints correctly, your system may have been out of memory or resources.
  • If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory. Then turn it back on and print a PDF.
  • If the file prints correctly, the printer's memory was too full or had become corrupt.
  • If the file still doesn't print correctly, go to step 5.
5. Print from another computer.
  • If the file prints correctly from another computer, the computer you first used may be unable to connect to the printer or the network correctly. Consult your network documentation or contact your network administrator.
  • If the file still doesn't print correctly, go to step 6.
6. Print a PDF to another printer.
  • If the file prints correctly to a different printer, the computer you first used may be unable to connect to the original printer. Communication, hardware, or memory problems can cause this kind of connection problem. Make sure that the printer is turned on and connected properly. Then run a self-test on the printer to make sure that it's working correctly. Consult your printer documentation for self-test instructions or contact your network administrator.
  • If the file doesn't print correctly, see "Can't print any file from any application" later in this document.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Lexmark Z611 InkJet Photo Printer
My HP 7410 will not do anything print fax scan.
go to control pannel .
xp computer: go to add and remove prg/
vista and win 7 comp: goto prog and feature.
turn off the printer and uninstall all the hp printer related drivers like essential and photo image s/w.
then restart the computer. and go to hp site.click on support and driver , key in the model num of the printer, select the correct operating system and download and run the s/w, turn on the printer when it prompts for. if installation is done correctly everything will work.
in case then also you have the problem then contact hp smart friend tel number: 866-211-5207 level 2 tech support. pay $59.99 validity 3 days and trust me they are best to fix such kind of issues. nothing to worry.
May 09, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Printer is not grabbing the paper to feed it through. Showing an E3 error but no paper is jammed. Appears to be a mechanical problem as the printer and computer seem to be communciating correctly.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 24, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper won't feed correctly. Printer pulls paper
Hello there
Feb 23, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma ip3000 won't print
Check usb cable if they are installed firmly and correctly. Check proper voltage input though designed as Autovolt system.
Try plugging the usb cable on another free usb port or you may try another computer to check if your printer works.
See if there are blinking lights and error codes. You can google for its error codes.
Check flex cable continuity, maybe some rodents have eaten it.
Remove ink cartridge, turn the power off and clean cartridge contacts including the holder contacts, turn it on and return cartridges. You may try borrowing a working ink cartridge of the same type from a friend.
Dec 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Tri Colour cartridge inserted is not intended for use in this printer msg
Try to clean the print cartridge contact points with a good rubber eraser and clean the printer side cartridge contacts with good lint free cotton cloth. Then first insert Black cartridge and then colour cartridge. Use some more pressure while attaching the cartridges.
Apr 22, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP LaserJet 3030 All-In-One Printer Logo
56 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
