Question about Mitsubishi WT-42311 42" Rear Projection Television
No red in picture
There is no red in the picture-intermittently
  • rheam414 Sep 26, 2008
    do I understand correctly that there are no bulbs to replace in this model-only something called "crt's"?
    okay, if a crt is a bulb-next question is are there seperate bulbs for red, blue ,and green or is there one bulb that runs the whole set and the lack of red in the picture is another problem
  • 85 Answers
A DLP set has a BULB sometimes crt's are called bulbs which in a way they are glass bulbs with phosphor and a vacuum
Posted on Sep 26, 2008
  • hiwatt Sep 26, 2008
    yeah red green blue bulb not like a light bulp old tv techs used to cal crt's bulbs they do in fact look like a bulb of glass.
Why does it switch on and off intermittently?
Check the power supply circuit for bad capacitors, you can tell which are bad by their bulging tops.
May 15, 2015 | Samsung Televison & Video
I have a Mitsubishi WS-55315 55-inch tv that suddenly without warning the picture seems to have lost all red color. The picture seems clear but it is mostly green in color. The problem is intermittant...
Hi
Check the componet cables if you are using them for video from the cable box, the red may of came loose.Also you could have intermittent connection the video processor IC or as we techs call it the jungle IC. It is responsible for producing all the small singals used by the set.Tapping with the handle of a screwdriver on the signal board may lead you
Jul 21, 2011 | Mitsubishi WS-55315 55" Rear Projection...
Intermittent fault when using sky+ box. Picture changes to red. Freeview pictures are OK as are the remaining analogue pictures. Scart lead changed and fault cured for a while then, back to the red screen
The most likely culprit is a poor connection between the two. Try reseating the cable between them when it happens, or try a new cable.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Panasonic CT-36HL43 36" TV
Green tinted picture
if it's intermittently losing the red you probably have a bad solder connection on the red picture tube board, if you have solder skills you can pull the board off and solder any bad connections to fix it. you can tap lightly or flex on the red tube board to make the red come and go to verify the problem.
Sep 08, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
Sony KP-53HS10 rear proj TV - picture goes on & off
If the adjustment of the screen settings does not fix your problem, its likely that one or more of the CRTs (picture tubes) is defective.
And, the CRTs for these sets are hard to find and expensive.
michtech
Jan 29, 2009 | Sony KP-51HW40 51" Rear Projection...
Red Tinting on Screen
30 YR SERVICE TECH.
YOU NEED TO TAKE THE SET INTO AN AUTHORIZED SERVICER. YOU HAVE EITHER AN OPTICAL BLOCK PROBLEM OR AN INTERMITTANT LVDS CABLE.
APGONZO
Jan 12, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Blinking power light
Start by counting the red blinks. This will hopefully tell you what the problem is. Then check back with the number of blinks.
Aug 17, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
No red in picture
It could be a dry solder joint on the base socket pcb. Try resoldering the base socket, and try for dry joints on the main board also. Check if the rgb voltages are steady on the crt driver transistor bases.
Jan 10, 2008 | Televison & Video
Mitsubishi WT-42311 42" Rear Projection Television Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
