Question about Optics
Newcon Optik Stargate M Problem
Hi Wayne, You gave the following advice for folks who's nigh vision things worked for a second and then faded out. "Unscrew front lens front of intensifier tube; should have an even bronze tinted coating on glass if it is grey and blotchy the tube is degassed. Common fault with this model nightvision wayne"
Is there a way to replace/repair this? Thanks Ray rpwillia0@earthlink.net
  • Optics Master
  • 5,342 Answers
There is no point in addressing queries to individuals, as they may no longer be able to assist. Your best option is to post the entire details of your query, so that anyone with the appropriate skill and expertise can endeavour to help you.
Posted on Aug 02, 2017
4 Suggested Answers
  • 15 Answers
SOURCE: Newcon Optik Night Vision Binoculars BN5
The lenses screw out, the electronics are in the body and this involves removing all the screws, including the ones behing the rubber casing. Why do you wish to strip them out?
Posted on Nov 29, 2008
stewbison
  • 577 Answers
SOURCE: We have the newcon optik.
Hello there, alway check the battery. It can be check with a DMM for voltage but the battery needs to have a load on it. Hook up a couple flashlight bulbs across the + and - terminals. Then check the voltage across the battery with the load (bulbs). If the voltage across the battery is about 2.6v on a 3 volt battery with the load it's OK. Example: The same with your car battery that has a 12 volt system.---put a DMM across the terminals and it show approx 12 volts. Try starting the vehicle and if the voltage dropes below 10 volt while trying to start the auto, then the battery is or needs to charge. or it's bad Example, to check you vehicle to see on DMM if it is really charging. Start the vehicle and let it run, then check the voltage across the 12 volt battery. It should be 13.8 volts. This will indicate that the charging system of the vehicle is work. stewbison
Posted on Aug 04, 2011
stewbison
  • 577 Answers
SOURCE: I have a newcon-optik stargate that will only come
Hello, it could a bad switch. Have you tryed hold down on the switch and see that works. If so, then the switch is faulty. You know that this NewCon Optik CON STARGATE-M is Russian manufactured by Optik one of the six or seven Russian companies manufacturing these NV devises. GB...stewbison
Posted on Aug 31, 2011
When it is turned on you cant make out anything .the only thing you can see is a outside light.You can see gree
There is a shield in there that only refects in the recile only and it has come loose or was never seated right most of these units are sealed and some are nitrogen charged In simple terms it is broke, if under warranty get a new one if not try pleading your case to the sales clerk, because they will probably counter with you dropped it. Right after it is designed to take recoil shots day after day. Al you can do is try.
Nov 22, 2011 | NewCon Optik NS 156 Weapon Sight
We have BN 5 Night Vision, but it's not in working condition means after putting batteries too it does not work. please let me know hw the problm can solve.
Hello, make sure that the batteries are installed in the correct order. Also, check the battery contacts in the battery compartment and make sure that they are really clean. GB...stewbison
Sep 06, 2011 | NewCon Optik BN-5 Binocular
I have a newcon-optik stargate that will only come on about 1 second after I press the lever. It only worked about a week after I bought it although I can't send it for repair under warranty right away...
Aug 31, 2011 | NewCon Optik CON STARGATE-M
Was wondering if there was anyway to take the lens off my Newcon BN356/BN456 Binoculars to clean them?
Yes, First, when you take the lens off you binocular make sure you are in a very clean room.
All you have to do is unscrew them. Use a good lens clean that is anti-static. If you don't every piece of lent, dusty bugs, flaky shin, etc. will be attached to those lens. stewbison
Mar 31, 2011 | NewCon Optik BN-5 Binocular
We have the newcon optik. Wer took the batteries out to store it. We want to use itnow,put batteries in and it dont work. The number on it is (n99703638)
Mar 22, 2011 | NewCon Optik Optics
Little black and white dots inside the lens
It's not a problem with your NV monocular. These spots will occur on any image intensifier tube. EXAMPLE: Military standard states that if more than one black spot appears on the tube, then this image tube is rejected for use by the US Military Now like you NewCon Optik DN 140M it manufactured in Russia and they quality control doesn't even match the US Military Standards. On scale 1 to 10; US Military rating for the image tube would be 10+ while the Russian maybe 2+ and I said maybe. Another thing to remember here is that no two image intensifier tubes are the same. It just like finger prints on people not two are the same. It normally. stewbison
Dec 05, 2010 | NewCon Optik DN 140 M
No image at all
Try replacing the batteries with brand name, photo quality AA's (energizer E2 lithium would be my first choice). 1st gen night vision devices (which is what the NS-156 is) are very sensitive to voltage, and cheap batteries just don't have the "oomph" to power up the intensifier tube. I've bought quite a few "broken" 1st gen devices for between $20-$50, "fixed" them with good batteries, sold them and usually at least quadruple my $$ off the deal. No guarantee, but it's a great place to start. Good luck!
May 14, 2010 | NewCon Optik NS 156 Weapon Sight
Nov 06, 2008 | NewCon Optik BN-5 Binocular
Night vision
go to google then click on shopping it is the best way to get items hope this helps.
Feb 21, 2008 | NewCon Optik NZT 22 Goggles
Newcon BN5 bipppppppppp
Try contacting these guys, i cant find any online info about this fault, it sounds like a serious problem in the circuitry that can be fixed - the biiiippp is an error message and the shutdown should protect from further damage; http://www.newcon-optik.com/contact_us.html Hope this helps :)
Mar 31, 2007 | NewCon Optik BN 5 (2.5x62) Binocular
Optics Logo
734 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
