Question about Hotpoint HTS20GCNWW / HTS20GCNCC Top Freezer Refrigerator
HOT POINT NOT COOLING WELL
I CLEANED OUT THE BOTTOM VENTS AND NOW IT SEEMS LIKE THE REFRIDGE AND FREEZER BOTH DONT SEEM AS COLD WHEN I PULL IT OUT FROM WALL IT SEEMS LIKE IT GETS COLDER. BUT I WAS UNDER LOOKING AT IT AND THE FAN IS NOT ON I AM NOT SURE IF THE FAN IS SUPPOSE TO RUN ALL THE TIME OR ONLY INTERVALS DOES ANYONE KNOW? ALSO CAN I JUMP THE WIRE TO SEE IF THE FAN KICKS ON OR IF MAYBE THE FAN WENT OUT. I CAN HERE THE UNIT RUNNING JUST NO FAN KICKING ON.
  • 958 Answers
If the condenser fan ( the one near the compressor) is not running and the compressor is running, then that's not good. try to lubricate the bushings of the fan and see if it would run. feel the blade if it turns smoothly. if it's sticcky, then there is your problem.
it should be running the same time as the compressor. if the compressor stops, the fan should stop too.
tnx 4using fixya,
drcool
Posted on Sep 26, 2008
Have frigidaire my freezer is working but bottom of refridge is not getting cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Frigidaire 18.3 cu. ft. Top Freezer...
Refridge. light went out. Bulb is good. Indicator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by side refridge was dirty and I cleaned
I would pull the refrig out , and remove the back panel , covering the compressor and fan motor . Check to see if the fan is working . Fan not working , causes the divider panel , to get very hot . Also , fan not working , causes the compressor to over heat and cut off on the overload .
Sep 29, 2009 | GE Refrigerators
Refridge quit cooling suddenly inboth freezer
That could be a broad range of possibilities. The defrost timer, adaptive defrost board,compressor start relay, compressor start capacitor or a mother board. Would you happen to have the model number so I can narrow down those possibilities? If you pull away from wall remove cover over the compressor and then unplug. Touch the compressor and let me know if cool, warm or too hot to touch. Thanks, Sea Breeze
Aug 19, 2009 | Kenmore Refrigerators
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
FREezer works fine,frig will not go less than 40 degrees and unit never cuts off
the problem is the freezer drain is plugged up. when the fridge goes into defrost,the water that is suppose to drain out has no where to go. so it refreezes . that ice has plugged up the blend air vents between the freezer & the fridge.
1st put your food in a cooler. Unplug the refridge.
(you may want to take pictures as you go.for the reassembling)
open up the freezer, remove the rear panel, & the bottom panel (if possible)
you will see the coils, underneith the coils you will see an metal tray. it will probly have ice on it.
with a blow dryer, heat the ice till you see the drain . now that drain has to be cleaned out.
that drain runs down to the bottom of refridge into a drain pan. with a wet vac , attach it to the drain tube, until you fell suction in the freezer. small amounts of hot water does help.
( it usually gets plugged up from bugs)
next , open the fridge ,on the ceiling of the fridge.there will be a plastic cover (most models) remove the cover carefully. usually there are 2 passiges from the freezer to the fridge. that is where the cold air drops into the fridge. there will probally be ice in these passages, which has to be removed.(be careful with the stirofoam)
once you have cleaned out all the ice ,reinstall all those pieces.
plug back in the refridge.It will tak a day for it to get cold again.( hint get 2 bags of ice to help speed up the cooling down process)
Apr 27, 2009 | Refrigerators
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
Compressor constantly on too hot to touch
hi have you cleaned the matrix best done by blowing with air but a soft brush can work,make sure that all the cooling vanes are clear
hope this helps ian
Jul 21, 2008 | LG LRTN22324 Top Freezer Refrigerator
Hotpoint HTS20GCNWW / HTS20GCNCC Top Freezer Refrigerator Logo
114 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Gil Shultz
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
