Question about GE Microwave Ovens
I recently went to another ge site with a question regarding a problem with a GE Microwave oven I purchased in August 2008. They wanted to charge me for service, this item is under warrenty, where do I go the get warrenty service?
  • 5,911 Answers
If you purchased the appliance in August 2008, the appliance is definitely covered under the manufacturer's one year limited warranty that comes with most appliances. You can contact GE directly by calling their Warranty Management department. The information below is from their website, geappliances.com:
For warranty questions, please write or call:
1-800-626-2224 M-F 8 a.m. -8 p.m. EST; Sat. 9 a.m. - 4 p.m. EST
For hearing impaired service call toll-free 1-877-885-2782.
If you wish to send correspondence, use the address below:
General Electric Company
Service Protection Plus™
P.O. Box 100
Rapid City, SD 57709
They should not charge you for a service that is covered under a warranty. Be prepared to provide your COMPLETE model number and serial number. Usually this information is located somewhere around the door opening, or on the back of the appliance. You should also have your receipt or purchase order. But...if you don't have it, the SERIAL number will indicate the MONTH and YEAR the appliance was manufactured. The manufacturer should still honor the warranty based on this information.
If you don't get satisfaction with this, you can try their Answer Center at 1-800-626-2005.
I hope you find this information helpful. If you do not get any where with this, please post back and let me know. Good luck.
Posted on Sep 26, 2008
GE Spacemaker XL4100 Model # JVM1450WA has stopped heating
If no fan, check the door switches. If it sounds like it is working then the ma
Dec 31, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
GE Mongram Mikrowave Built in 10 years old. Everything works exept it does not heat, is it worthwhile to repair? regards Heinz
Maybe...
The magnetron proably went out...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 08, 2010 | GE Monogram ZEM200SF Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I believe the magnetron just went out
Make a few phone calls and get the actual costs-then decide. You cant normally fix microwave ovens yourself though. Generally when the magnetron goes its time to buy a new micro unless its under warranty.
Oct 03, 2009 | GE JVM1410 Microwave Oven
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I purchased a GE microwave oven in March 2008. It was working just fine, then I went to use it again, and it will not heat anything. The light comes on, the turn table turns, but does not heat naything. ...
I'd say you have a bad magnetron, but it will have a full one year warranty on parts and labor.
Let GE fix it for you free. GE Customer Service is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 25, 2008 | GE Microwave Ovens
Looking for Temperature probe for JVM1190
Most any standard microwave temperature probe should work, from places such as Wal-Mart, Home Depot, Lowe's, etc.
Nov 21, 2007 | GE JVM1190 Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
49 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
