Resolution I have a MAG MA-32EF1AC LCD TV that I use as a monitor. I need 1024X768 resolution to work with a video program. This resolution is not supported by the monitor but it will work if I "trick" the computer by hooking up a monitor which DOES support this resolution, unhook that monitor and hookup the MAG without shutting off the computer. This works but is cumbersome especially if the computer shuts down for any reason, then I have to do the same thing again. I have XP pro. Are there any drivers for other monitors that I might download that might solve this problem? The Innovision web site is of no help as they offer no drivers of any type.
  • Joshua Dobers
    Joshua Dobers May 11, 2010
    What video card do you have? There are special programs (and settings sometimes in the drivers) that allow you to change the resolution on the monitor.
    Another option is to set the driver for your monitor to "generic plug and play monitor" that way you should be able to set it to the resolution you want..
It is an Intel Express Chip set Q965/Q963, an integrated card. I'm not at that computer right now, but I believe it is already a generic plug and play driver.
Posted on Sep 29, 2008
I have a MAG MA-32EF1AC TV that will not turn on and no longer has power - there is no light, red or otherwise showing on the TV.
hello make sure the socket yourusing is working ok, you may have a blown fuse in the plug, if ok you may have a blown fuse in the tv thanks
shaun
Feb 15, 2017 | Televison & Video
Mag LCD TV MA-32EF1AC has power but won't turn on with remote or with power button on side of tv screen
If neither the remote nor the tv power button has any effect then it is safe to say that you may have an issue with the power supply section of your set.
Jun 22, 2016 | Televison & Video
Ccfl
Hook a monitor to the video output, if picture is present it indicates a problem in the inverter board just below the LCD screen, [more commom] or the backlight behind the display is defective. Now! if both show the same symptom it is most likely the video graphics chip.
Jul 06, 2012 | Computers & Internet
TheLCD is not working on resulution 1024x768 do i need any driver
Yes, it is very possibility of driver problem, but you can check it to attached with another PC. If the problem will persist you need to drivers. And another possibility is the LCD did not support 1024x768 resolution.
Good Luck
Mar 04, 2011 | Hyundai Electronics L19T+ LCD-TV 19"...
Can't get my Dell Precision M50 Laptop video to fill the screen at 1024 768 resolution. Video will only fill the screen when I set resolution to 1600 1200. Is there something wrong with my video card?
1024x768 is a native wide-screen resolution. more than likely your video card is fine and your notebook monitor does not support that format without shrinking the top and bottom which defeats the purpose of filling the whole screen. plug the kappy into an external widescreen monitor or TV and it will work at 1024x768.
Regards
Jun 06, 2010 | Dell Precision M50 Notebook
If connected to a 64 bit Dell Studio, it is difficult to view monitor. can you help? It works perfectly on a HP pavilion, but not the dell
Your resolution is probably not set correctly. That monitor can only support a resolution of 1024x768 - so to change that, you'll need to go into Start - Control Panel - Display Settings, and then click on the settings tab, and near the bottom where it says "display resolution" drag the slider until it says 1024x768. Press apply or ok and see if that helps.
Jan 20, 2010 | Mag Innovision lt456s 14" Flat Panel LCD...
My monitor blinks at random intervals at 1024x768 resolution but never at 800x600.
Your Video Card doen't support the 1024X768 that is why your first resolution is blinking and your second resolution is staying on.
Dec 06, 2009 | Gateway FPD1975W 19" LCD Monitor
MAG flat screen TV
If you have sound, it means the LCD is either dead or the video firmware has locked up.
You'd hope it the firmware. To reset it, the easiest thing for you to do is pull the plug, wait 1 minute and replug it.
Didn't work?
Then the LCD panels are made by Quanta Display Inc. (QDI) of Taiwan. A common problem with cheaper LCD panels is the backlight goes out, so the screen is black but there actually maybe a picture there if you look close enough. If so, its likely a dead bulb. It will need professional service unless you know someone savvy with electronics.
Sep 11, 2008 | Televison & Video
Maginnovision LCD Monitor
You probably have a bad filter Capacitor in the power supply. Schmatics would help locate the faulty component, also you can tear it apart and look for any water intrusion. My wife cleaned the TV screen with windex and it ran down the screen and into the TV. It destroy a menu button which had to be replaced. It caused unusual simptoms.
NSSMS
Apr 04, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Computers & Internet Logo
186 people viewed this question
David Payne
David Payne
