Question about HP Office Equipment & Supplies
How do i check ink supply left in cartridges - HP Office Equipment & Supplies
  • 35 Answers
Hi there
Thanks for posting your problem on fixya
the cartridge will be seen moving left and right whenever you take any print out... just open the flap you will see the cartridge.. try to pull out slowly some printers doesnt have flaps..in such cases just put your hand inside the printer and try to pull it out. Take out your cartridge and see the ink level if your has ink it means your ink supply is correct otherwise refill it
Is this solution helps you then please vote for me
Thanks
Robert
Posted on Sep 26, 2008
I bought a new 952 black ink cartridge and it still says ink too low Is there something to remove before you install the cartridge?
Donna, typically there is a protector that covers the ink dispenser's copper contacts.It may be in the form of a protective sticker or a piece of plastic over the cartridge's dispenser. Hopefully you removed the protective cover before installing the ink cartridge
Some printers, like HP are proprietary and require their genuine brand cartridge for replacement...generic brand cartridges or refill cartridges are normally rejected.
Other printers, like Brother, have a sensor, while others may have a software program that "predicts" when your printer is out of ink; triggering a fault code- when in fact there is still plenty of ink left in the cartridge.
And yet, there are cartridges, like HP, that have a date chip in them such that when the expiration date of the ink cartridge comes about, even though there is ink in the cartridge, the printer will no longer function... a word to the wise, when purchasing an ink cartridge, check the expiration date stamp on the box.
Since you did not mention the printer name and model or the name of the ink cartridge, my remarks are generalizations- and not printer specific
Feb 13, 2017 | The Office Equipment & Supplies
Disable ink detect on mac epson workforce 610
Aloha, Epson have a bad reputation for making people buy only their cartridges and get lots of money for them but there is a way around them by never doing firmware updates and if you did there is a software program that allows you to down grade the firmware so you can use 3rd party cartridges it is called "Wicreset" or another program called "SSC Service Utility " to check and adjust ink levels. google them for their web addresses. Good luck...
Oct 17, 2017 | Epson Office Equipment & Supplies
Epson C60When I press the ink replacement button, the print head doesn't move to the center. Previously, I had purchased a ink cartridge that turned out to be too large, so I took the ink cartridge...
Unplug the printer from computer, then Unplug the printer from wall when the carriage is all the way to the left, then manually slide it to the area where you can open the ink cartridges, pull all ink cartridges out, close cover and turn printer on. Printer should now be acting as it should.
May 17, 2017 | Epson Stylus C60 InkJet Printer
My epson printer won't print or scan anything, and can't seem to find the fault. Warning light on the left hand side of the printer indicates that the ink is the problem, so i have checked the inks...
Most likely one of the ink cartridges is out of ink. The Epson printers I'm familiar with all will not print if any one of the cartridges is empty. Most likely it will tell you which cartridge needs replacing.
Oct 11, 2017 | Epson Stylus® DX4800 AllInOne InkJet...
Dell 944 instruction to install new ink cartridge
Replacing Ink Cartridges
CAUTION: Before performing any of the procedures listed in this section, read and
follow the safety information in "CAUTION: SAFETY INSTRUCTIONS" on page 9.
Dell ink cartridges are only available through Dell. You can order more ink online at
www.dell.com/supplies or by phone. To order by phone, see "Ordering Supplies" on page 2.
Dell recommends Dell ink cartridges for your printer. Dell does not provide warranty coverage
for problems caused by using accessories, parts, or components not supplied by Dell.
1 Turn on your printer.
2 Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
3 Press down on the ink cartridge lever to raise each ink cartridge lid.
4 Remove the old ink cartridges.
5 Store the cartridges in an air-tight container, such as the storage unit you received with
your photo cartridge, or dispose of them properly.
6 If you are installing new ink cartridges, remove the sticker and transparent tape from the
back and bottom of each ink cartridge.
7 Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the
left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge
carrier.
8 Snap each lid closed.
9 Lift the printer unit, and hold the scanner support up while lowering the printer unit until
it is completely closed.
See page 71, section 7 in the user guide:
http://support.dell.com/support/edocs/systems/944/en/om/om_en.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | Dell Photo 964 All-In-One InkJet Printer
Hi Folks: I would appreciate any help and suggestions: HP DesignJet 1055CM error 0A0020 006501D1 Thanks, Paul
"Error in calibrating the APS sensor"
APS= Air Pressure System - it provides air pressure to pump in to the ink cartridges, thus pumping ink to the printheads through the ink tubes.
First things to try
- Remove all Ink cartridges.
- Power down printer.
- Power on.
- Place cartridges in ink supply station, check if they are recognized.
- Replace the one cartridge that is almost empty.
- Check all cables and air tubes in the ink supply station. (you need to remove left cover of printer)
Make sure they are all properly connected and not damaged.
Make sure the air tubes are free running - NOT pinched or bent!
- Lastly,
When all above fails, replace faulty APS sensor and / or pressure valve.
Oct 30, 2010 | Computers & Internet
Printer is feeding paper and ink cartridges are showing plenty of ink, but there is no ink reaching the paper. The sponge pad on the left side is sodden with ink
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
Dell 810 giving Incompatible Ink Cartridge error message
Hi try these steps
STEP: Disconnect and Reconnect the Printer Power Supply
Top of Form 1
Bottom of Form 1
Unplug the power cord from the wall socket.
Disconnect the power supply from the back of the printer.
Wait 15 seconds.
Reconnect the power supply to the back of the printer.
Plug the power cord back into the wall socket
STEP: Clean the Contacts and Wick the Ink Cartridge
Ensure the printer is powered on.
Lift the scanner unit.
Open the cartridge latches and remove the cartridges from the carrier
Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back.
Turn the cartridge so that you are looking at the contacts on the back side of the cartridge
Using a clean dry cloth, wipe the contacts so that no dust or other contaminants are visible
Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
Replace the cartridges in the carrier and close the scanner unit.
STEP: Verify Each Cartridge Carrier Has an Ink Cartridge
Check to make sure the left cartridge carrier contains a black or photo ink cartridge.
Check to make sure the right carrier contains a color ink cartridge.
Remove each cartridge and examine it to make sure the protective tape has been removed from the contacts and the print head.
Replace each cartridge in the proper carrier.
Let me know the status.
Regards
Jan 07, 2008 | Dell 810 All-In-One InkJet Printer
263 people viewed this question
Ben Johnson
