Question about Indesit W 123 Front Load Washer
Hot water solenoid not energising i.e. no hot fill.
When machine switched on, hot water is supposed to enter machine, no electrical supply to hot water solenoid i.e. valve not opening to allow hot water into the machine.
Is there a sensor of some kind that could prevent the solenoid energising? Say, a thermostat, a pressure switch, or something on those lines that could be responsible?
Please help.
  • 958 Answers
Check the water setting.
it could be set to cold and not warm or hot that is why it is not energizing the hot water solenoid.
tnx 4 using fixya.
drcool
check also temperature setting of water. if it is set to cold, then hot water will not be energized. or it could be the defective part.
tnx again,
drcool
Posted on Sep 26, 2008
Water keeps filling
if it's filling all the time with the machine electrical supply turned off the problem is the water supply solenoid valve is faulty could be hot or cold solenoid,
if it's constantly filling with the machine switched on it's possible the water pressure switch that is faulty or more than lickly the small rubber pipe that connected to it ,is blocked find it disconnect pipe blow down pipe to clear ,replace test not forgetting to disconnect electrical supply before removing any covers.
Nov 13, 2016 | Washing Machines
I have a 2008 Yamaha YDRE electric golf cart, I replaced the solenoid. I have checked the key switch, the f/r switch and the toggle switch. I only have a positive reading on one side of the solenoid.
Only the battery side of the solenoid will be live until it receives an energising supply from the control circuitry and closes. In the energised and closed condition both sides of the solenoid will be live.
If an energising supply is present at the solenoid coil the solenoid could be faulty. If the energising supply is absent the control circuitry is at fault. Tracing the fault could be made easier by referring to a wiring diagram.
Oct 14, 2016 | Golf
Machine wont fill with hot water
problem in hot water tap
hot water solenoid not activating to let water in
to prove either switch the hoses on the taps and press cold water wash
that proves the tap
then press hot wash and that proves the solenoid
Jul 21, 2016 | Fisher and Paykel Washing Machines
My LG TROMM Hot water continually fills even after machine is turned off and unplugged. I have to shut off water supply to stop it.
Unplug the washer removing all electrical power from the machine. Turn the water back on and confirm that water is still entering the machine.
If the condition is true no power to washer and water enters machine it is very likely that the fill solenoid has failed.
this part is not that difficult to replace.
Water Inlet Valve part 5220FR2008F LG Washer Repair
Dec 31, 2015 | LG Washing Machines
All lights are working belt is attached dunno why ifs not filling up or moving when I switch a wash program on but make a slight buzz as if it wants work
How to Check a Washer when Is Not Filling With Water OTHER washers test similiarly
# Test procedures to follow when a GE Hotpoint washer is not filling
* Disconnect the washer from the wall outlet
* Set the timer dial on regular and pull the knob to turn the timer push-pull switch on
* Set the temperature switch to the cold/cold setting
* Open the controls panel to gain access to the water mixing valve solenoids
* Touch the 2 terminals on the cold water solenoid with your volt meter test proves. Make sure that your body don't touch the washer cabinet, this eliminate the chance of getting an electrical shock.
* Have someone plug the washer cord for you while you check the voltage
* The reading should be 120 volts
* Touch the 2 terminals on the hot water solenoid with your volt meter test proves. Remember, to keep your body from touching the washer cabinet to eliminate the chance of getting an electrical shock
Have your helper plug in the washer cord again so you could check the voltage at the hot water solenoid
* The reading should be 120 volts. If you get 120 volts, this tells you that the wall outlet, the timer, the water temperature switch cold and hot water settings are working ok.
If the GE Hotpoint washer is not filling, the problem should be on the water valve, the screen filters or the water supply
If one of the solenoids is bad you will need to replace the complete water mixing valve assembly YOU SHOULD ALSO GET AN OHMS READING OR SHOW CONTINUITY WHEN TESTED UNPLUGGED ON BOTH SELINOIDS HOT AND COLD
Mar 29, 2015 | Washing Machines
Hot water is delivered to the washing machine but will not enter the machine. Cold water will enter the machine. Model #LAT9457AAM.
Make sure that the machine is not selected to 'Cold Wash'. Otherwise check if there is a screen in the supply line, these can become blocked due to scale deposits from the mains. If there is no screen check that the inlet solenoid valve has not got blocked. If none of the above help, check that there is power getting to the solenoid valve when the machine is supposed to be on the fill cycle. If no power is getting to the valve, the timer might be faulty. (You can try hand filling the machine and see if it goes through a cycle, at least up to the rinse stage, this will tell you if the timer control is working).
Jun 22, 2011 | Washing Machines
Hot water connected but does not fill into the drum? The machine will provide us with a cold wash but on the warm and hot settings the hot water dies not pull through the connection
Turn off the water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses and tighten. Turn the water valves back on and try to run a wash cycle using cold. If hot water only is entering the wash tub the water supply is ok. If this is the case you can unplug the washer and turn off the water valves. Remove the washer back cover and follow the water connection for the hot water. The water solenoid valve will have two electrical wires connected to it. Interchange the hot water solenoid wires with the cold water solenoid connection. Connect the water supply hoses hot to hot and cold to cold then plug the unit then test the washer on the cold wash. If the problem persists it could be a water hose restriction or the timer circuit could be defective. If you have hot water at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to restore the correct wire connections on the hot and cold water solenoid. To replace the hot water solenoid remove the hose clamp and hose to replace the old valve. Connect the unit to the water and electrical outlet. Turn on the water and test the unit for leaks being careful not to touch any electrical and moving parts. If all checks ok and the correct temperature work, unplug the unit and reassemble.
Jun 21, 2010 | Admiral AW22 Top Load Washer
Hi there my hotpoint washing machinewma 54 fills up without the machine being on
Hello. your fill valve is faulty and needs to be replaced.
here is how the fill valve is supposed to work:
The fill valve--which is about the size of a coffee cup--is sometimes also called a "water inlet valve." It controls the entry of hot and cold water into the machine. The valve has three major components:
  • A hot-water solenoid
  • A cold-water solenoid
  • A mixing valve body
The inlet valve has three hoses connected to it, for :
  • The hot water from the house
  • The cold water from the house
  • The water directed into the washing machine's inner tub (either hot or cold, or both) to fill it with water
When electricity flows to one or both solenoids, water flows through the valve into the washing machine's inner tub. When the electricity stops, the water also stops.
Aug 21, 2009 | Washing Machines
Water solinoid staying closed when turned on
Usually energising electricity to a solenoid will allow the water to flow. Try your unit with the water line from the solenoid unattached. Then you will know when it is trying to get water to the ice maker.
Apr 28, 2009 | Refrigerators
Kenmore oasis long fill
Check your hot and cold water supply hoses for residue buildup that restricts the flow of water.....there is a small metal screen filter that clogs up ....most likely the cause if your pipes are old and the inside walls are shedding deposits into the water line.
Jul 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Indesit W 123 Front Load Washer Logo
115 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
