I install the print but i cant print - Office Equipment & Supplies
  • claudiasanto Sep 28, 2008
    if i want to print says i have a error
  • 65 Answers
Here is what I would try.
First - Unistall all drivers and software that came with it. then unplug printer and reboot. be sure to also remove the hardware from the device manager. (right click "my computer", then go under properties, then hardware tab, then click device manager)
second - preform a windows update, if it hasn't been done in a while, many times service packs ect. include a new standard driver pack. then reboot...
third - hook up all cabling to the printer while it is turned off..be sure not to use a usb hub, but directly in the back of the PC if at all posible, those hubs are always problamatic.
then fire that bad boy up, let windows do the driver search for you. it should see the new hardware, and install the drivers, worste case it may ask "preform a windows update to find driver" go ahead and do that it will look into the windows library and find you a driver.
hopefully that will do the trick..
Posted on Sep 26, 2008
Cant print nothing
Try unplugging your usb cable to the printer, uninstalling the printer software, reinstalling the printer software, and plugging the usb cable back in when instructed during the installation.
Mar 08, 2014 | Dell Inspiron 530 Desktop Computer
I have a lexmark x1240 and just installed a new cartridge. I keep getting an error message that says " print cartridge missing" install print cartridge even though both cartridges are in the printer.
If you insert the old cartridge, does it recognize it? If it does, then it's a problem with the new cartridge. Try to check if you already have taken out the protective tapes out of the cartridge.
If it still doesn't recognize the old cartridge, then it's a problem with the printer.
Nov 29, 2012 | Lexmark X1240 All-In-One InkJet Printer
How do i get my hp1200 printer to print, is on a off line mode
Hi Joy,
Disconnect the printer completely from the PC.Unplug its power cable too.
Reboot your PC.
Connect everything again from scratch but use a different USB port to connect to the PC.Make sure everything is well connected.Try printing now.Cant print?
Under printers and faxes,check whether 'work offline' is checked by right clicking on the printers icon and 'Uncheck.Still cant print?
Uninstall the printer driver on your PC,reboot the PC and install software again.If you don't have the installation disks,install from this Hp Support site making sure you select the driver that corresponds with your Operating System[Windows 7,Vista,Windows XP etc]
Hope this helps.Thanks!
Please rate this answer.
Dec 02, 2011 | Office Equipment & Supplies
My printer will not print. It prints a test page fine, but will not print any other documents
hi,
  • Check the status of your printer by moving to printers and faxes on the start menu.
  • Is it checked?Are there any queued print jobs?
  • Turn off both the printer and your PC.Remove the usb connections.
  • Unplug them completely from power.
  • After a few minutes connect them again.
  • Try to print.Cant print?
  • Uninstall printer[hoping you have installation disk] and install it again.
  • Make sure the selected ports on pc and printer correspond.
  • After installation restart your pc.
  • Now you can print!
Sep 20, 2011 | HP Photosmart C3150 Printer
Hi there. I have a HP LaserJet P1006 printer and a laptop with Windows 7. The print jobs get stuck in the que and I cant delete it. I installed the cd software many times, and I have installed the software...
you are installing the drivers may be not correct. u remove the printer driver and install the proper driver again otherwise it may be spooler problem then u have to reinstall the os and configure printer dirver
Apr 07, 2017 | HP LASERJET P1006 Printer
Dell 725 printer wont print after windows 7 install
You need the correct drivers for the printer. Go to Dell's support page and download and install the Windows 7 driver.
May 27, 2010 | Dell 725 InkJet Printer
Problem with canon mx308
you cant print you mean thats easy youl need to install the printers driver ok if you think how i gonna install the drivers then youl need to serial with that program just search on youtube: Uniblue Driver installer serial or keygen now after the install open it thenclick start scan & if ther any out of date just click on download & install its simple huh?
Apr 03, 2010 | Canon MX300 Office All-In-One Printer
I cant print it is showing e5 on printer screen
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-3
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cannot print from any program
u have some problum to install the printer, remove all printers and then again install it...
this will help u a bit....
take care,
good luck.
shakfy
Jun 26, 2009 | Apple PowerBook G4 Mac Notebook
My epson c90 cant print
make sure all of the drivers are installed. also make sure that the print memory is empty because it was probly printing when you ran out of ink,and could still be waiting to finish.
Dec 04, 2008 | Computers & Internet
22 people viewed this question
jasbo
jasbo
