Question about Sigma AF 70-300mm f/4.0-5.6 DL Macro Super Lens for Canon-EOS
Sigma 70-300 mm lens wont focus
Help, I've my sigma 70-300 mm telephoto lens wont focus in manuel or auto. I put it on my canon rebel xti. Sometimes it will focus but the pics look blurry.
Thanks
  • McKinleyAve Feb 18, 2009
    I can not get my sigma 70-300 mm lens to focus in maunal or auto mode with my Canon-EOS either. I just sent mine in to the Sigma repair center. I do not have the cost to fix it yet.
I was focusing to close to the subject & too much glare from a church window.
Posted on Sep 28, 2008
Why does my lens only zoom to 200
Could be, because most camera's only can auto focus till f/1:5.6. And if 5.6 is reached at the focal length of 200 mm, the camera stops it from going to a part it can't be focused.
Perhaps you try the lens in manual focus, and manual zoom.
Jan 28, 2014 | Sigma Zoom Telephoto 170-500mm f/5-6.3 APO...
Will Sigma 75-300 f/4-5.6 DL work on my rebel XTi
If the lens has a Nikon mount (as you imply in the post), then no, it will not fit. If it has a Canon mount, then yes, it will work fine on your Canon Rebel.
Jun 28, 2010 | Sigma 75-300mm f/4-5.6 DL Lens for Nikon...
I was given a sigma mirror-telephoto lens (600mm) It says right on it that it is for a Cannon. I have Cannon Rebel xt and cant figure out how to attach it. Does it work with a Rebel? And if so how? Do I...
You need a T-mount ($30) for a Canon on E-bay or a big camera store. There is NO connections to the camera body, so you have to turn off auto focus and go to "Auto" mode (the shutter speed will change) as the lens is fixed at F8. The mirrors give very little depth of field, 4 or 5 feet when far away but everything in back is a blur of circles. At F8 the shutter speed can go slow and at 600mm you may need a tripod.
Jul 18, 2009 | Sigma Super Telephoto 600mm f/8.0 Mirror...
Autofocus gives erratic results
Are you using this indoors, in low light perhaps? This would be the most common reason for this happening. The only way to get around that is to use a "faster" lens, such as f2.8 / f1.8 / f1.4 etc.
If not, try cleaning the lens and camea contacts with a plastic eraser, make sure no debris falls in the camera body (hold upside down for this).
Jun 02, 2009 | Canon EOS Digital Rebel XTI Digital Camera
28-80 mm sigma won't auto focus
The lens may not be a dynex type so it wont work on your 700
Nov 27, 2008 | Canon Sigma 28-80mm f/3.5-5.6 II AF Lens...
Sigma 28-300 3.5-6.3 won't focus
Did it ever work on this camera?
I have seen some Sigma lenses that are auto focus on canon film cameras but then when put on the digital they dont work right. If you have used it on this camera then make sure the lens is clean.sometimes dirt on the front wil make it try focusing on the dirt. Next try focusing in manual focus to make sure the focus is working. Then take the lens off and then put it back on and make sure it clicks into place.
Let me know if none of those things work. also make sure to try focus on something close and somthing far away.
let me know how it works,
Caleb
Jun 26, 2008 | Sigma 24-70mm F3.5-5.6 AF Zoom Lens
Camera lens
Hey kgconstruct,
The lens description that your posting is categorized under is a 75-300 f/4-506 DL lens for Nikon AI. If this is correct then no this lens won't work on a Canon camera. I am assuming this isn't correct and the lens you have is for a Canon camera, and if this is true this lens should work on the XTI. If you’re thinking of buying this lens I would go to a local camera store that carries this Sigma lens and try it out first to make sure you like it. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 16, 2008 | Sigma 75-300mm f/4-5.6 DL Lens for Nikon...
Sigma APO DG 70-300mm 1:4-5,6 sometimes does not af(Auto-Focus)on Canon Rebel XTi in macro, with extension tubes almost never.
I think you should use the manual focus for best results. the autofocus might not provide the best results at most times.
Apr 18, 2008 | Cameras
Trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature)
Capable of macro photography, this lens has a 1:2 maximum close-up magnification at the 300 mm focal length. It's the ideal high performance lens for portraits, sports photography, nature photography, and other types of photography that frequently use the telephoto range. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing distance is 1.5m / 59 in. at all zoom settings.
Dec 25, 2007 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Open Questions:
See all Sigma AF 70-300mm f/4.0-5.6 DL Macro Super Lens Questions
Sigma AF 70-300mm f/4.0-5.6 DL Macro Super Lens for Canon-EOS Logo
882 people viewed this question
Top Sigma Cameras Experts
Steve
Doberman
Are you a Sigma Camera Expert? Answer questions, earn points and help others
