I just replaced my convergences on my rear projection panasonic tv. i went and turned it back on. it stays on for about 2 seconds and them shuts off. could it my by sotering job? before i replaced the two parts my red and green were all over the place like a 3d movie.
    Novelist:
    Champion:
  • 203 Answers
Make sure that there are no solder bridges between the i.c. pins. Check all low value resistors for the correct readings with an ohmmeter. Also, sometimes after replacing the convergence chips you must replace the open pico fuses.(small, resistor-like fusable links that are soldered into the board). Occasionally a full realignment must be done to reconverge the three projection tubes. If it is digital convergence you will need the service manual or a trained tech. More than likely you just need to remove any excess solder and solderwick helps with that. Good luck, Russmann.
Posted on Sep 26, 2008
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Power wont stay on light blinks 3 times
your convergence ic are short
repair about 350
May 02, 2010 | Panasonic PT-47WX53 47" Rear Projection...
AKAI rear projection TV won't turn on
possiblity convergence needed...
main power board malfunctioning
contact akai service center
Apr 26, 2010 | Akai PT4298HD Rear Projection Television
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
SD Tech I replaced both convergence chips with two news one. Now with TV on table when I turn it on the projection lights do not come on and the TV shuts down in a few seconds. jaybirdwv
there is still a component problem in the t.v. send it back to the tech. if the convergence chips have failed again, the power supply circuit should be checked.
Nov 11, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53TW53G 1 Blinking red light, will not stay on.
just got back today for same problem. convergence went out. took to repair shop. $200 part plus $60 labor. second time in a year convergence went out. was told it will happen again.
Mar 19, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Power does not stay on!!!
3 blinks in that model means convergence. change your convergence ICs and possibly the resistors located right next to them. Thats what is causing your set to go into protective mode and the blinks are a self diagnosis feature. Let me know if you need any additional info.
Feb 15, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53WX54
you have defective convergence amps and should be replaced by qualified tech....john
Sep 10, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic PT51HX41E
you need remote control that came with tv ,there is a service code menu for techicians only - setting convergence on these sets are not easy.you Must Know what you are doing other wise you can shut set down with bigger problems.Call a repair shop if your not sure.I have service codes but ,i will not tell someone these codes unless they do know How to set convergence.
Oct 23, 2006 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
