Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Re; bissell shampooer
I just took apart my shampooer and fixed the part (crank) that turns my brush..it was completely broken. Now my problem is is that I cant get the suction part to work really well. Dont know if when I took it apart that I miscalculated and connected a wrong hose or crossed them somewhere. I have more water on my floor and it looks like the dirty water coming back onto the floor because it's not clear and clean it's brown and dingy.
Help...I know I can fix this but dont have a quide to show me which cord goes where. I know this much...very front center 3 connections hoses. I think the one that came from the right sid eof the vaccuum goes into right(common sense), but not sure on the top and left.
Thanks.
SOURCE: Bissel Proheat Carpet cleaner
My Bissell had the same problem. The hand attachment does not use heated water. So I Found a clog of calcium and dirt in the heater portion of the unit. The heater is in the handle behind the red heater light on the front. Remove the upper portion of the handle. Remove the lower two screws in the lower portion and the parts will split apart. Remove the hoses and remove the heater. (mark where the wires go) The bottom of the heater can be removed with a screwdriver. The tubes leading into the heater is where the clog was but there was a lot of debris inside Make sure to clear it all and the hoses as well. I put it together and it works great.
Posted on Nov 25, 2007
  • 126 Answers
SOURCE: need help putting my bissell carpet shampooer back together
I don't know how to advise you on this. The Bissell is pretty complicated when you take the hood off. Under there is a number of things that must be in place correctly to replace the hood. There is a small plastic "rod" with an "o" ring on it that controls the shampoo mixture and that has to be positioned right to replace the hood. You may have to take the machine to an experienced shop to have it re-assembled. I don't think I can tell you all the little things you have to do to re-assemble it yourself.
In regards to the elevator, there are two arms that lift the brush off the floor when the handle is put in the upright position. This is so the brush will rotate freely while you use the hose. These arms break quite easily and are available from any repair depot in a set.
You may be able to get a schematic diagram from a warranty service dealer. They have a special "dealer only" web site that they can access to get repair and parts info. Usually, they can e-mail or fax you information if you're really nice to them. Smile when you're on the phone. :)
Posted on Jan 27, 2008
Agent Don
  • 310 Answers
SOURCE: on my bissell shampooer, model
Generic problem for all Vacuums
On my Bissell shampooer, model
On my Bissell shampooer, model 7901-b i have no suction
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
If you have no suction, you could have a base seal in the recovery tank, there could be a clog or blockage, or check the clear tubes to see the they are crimped or pinched so that the vac is not getting any air, or start from the bottom and work your way up to where you do get suction and you should find the problem, a lot of times it is a gasket or the recovery tank is not on there securely or you may have a broken part that needs replacement. So feel free to check with the local vacuum cleaner dealer in your area in the yellow pages under vacuums, check the trouble shooting section to your owner’s manual or call the factory or check the website and maybe down load or have them mail out a owner’s manual.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac Man
Posted on Apr 22, 2008
reddevil6
  • 1673 Answers
SOURCE: bissell carpet shampooer
First check that the top cover on the back side hasn't come loose. Sometimes the plastic around the screws break away and the top starts to separate, raising the tank, and no spray. Make sure that the gaket is on the valve at the bottom of the tank and not sitting loose in the hole. Check the pump belt. The pump may be bad.
Posted on Jun 17, 2008
Junoon007
  • 1011 Answers
Dear Sir/Madam,
- Remove the tool from the end of the hose and see if the hose will spray. If there is spray with the tool removed, the tool is clogged. Clean out the spray tip of the tool with a safety pin or paper clip.
- Stretch the hose out and give it a few light tugs to release any kinks in the internal water supply hose.
If there is still no spray through the hose, please take your machine to a local BISSELL Authorized Service Center. To locate your nearest BISSELL Authorized Service Center, please go to www.bissell.com under the Customer Center tab near the top of the homepage. Enter your zip code in the Service Center box on the right of the page to perform your search.
Thanks
Good luck
Don't forget to rate the solution
Posted on Jul 20, 2008
My bissell shampooer 1694 model brushes will not rotate
mine rotates but not smooth...as the part on one side of the roller brush seems to be broken
Sep 28, 2011 | Bissell Powersteamer 1694 Upright Vacuum
General assembly for bissell proheat shampooer
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
6wywe
Jul 23, 2010 | Bissell 8910 ProHeat Clear View Upright...
Need help putting my bissell carpet shampooer back together
the side that is dragging needs the roller that the brushes are on ,to be precisly pushed back up in it's place,it will take a few minutes and it will not slide back in place easily just use a little force as for the hose diagram, bissell.com,enter model number and go to hoses.
May 31, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissel shampooer
yes there is a belt on the side that will need to be changed
Jan 13, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
How to put the double brushes back on the shampooer after cleaning them
I took the shampooer to a repair shop yesterday.. They had it ready to pick up the same afternoon.
Thank you for sending your reply.
Oct 14, 2008 | Bissell 1699 ProHeat Clear View Upright...
Need help putting back together
With out seeing it, it will be hard to figure out what isn't right. Must be a different model then 1699. which model is it?
Nov 08, 2007 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
55 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
