Question about True T-49 Side by Side Refrigerator Commercial
Extreme condensation, pooling in the floor of T-49
Over the past several weeks we have had to sponge out excess water that has formed on the floor of the T-49. Fans appear tobe working and its been holding temps properly. Any ideas?
  • 51 Answers
Please check your drain. These units have a drain pan for the condensation. After these units have been running the drain may develope a build up of debris.
Posted on Feb 20, 2009
What does convection in a weather forecast mean?
[img src="http://www.weatherquestions.com/convection.gif" alt="atmospheric convection forming a cloud"> What is convection? "Convection" has several, related meanings in weather....but it always involves rising air. It usually refers to "moist convection", where the excess water vapor in rising air parcels condenses to form a cloud.
The heat released through this condensation can help to sustain the convection by warming the air further and making it rise still higher, which causes more water vapor to condense, so the process feeds on itself.
But convection can also be dry, as occurs on a sunny day over the desert, or in more humid regions early in the day before the convection has become strong enough to form clouds. The sun warms the ground, and convective air currents help to remove the excess heat from the surface. Dry convection also occurs during the day even when clouds are not forming...you just can't see it.
Apr 16, 2014 | Ovens
Pool cleaner floats in water
pool cleaners that twist,wheelie and flop over all most allways a problem with the hose, plastic hose gets a memory that needs to be relaxed once or so a week to keep knots and kinks from forming , also replace hose every 3//4 years to as they just get too beat up to work effectivly any more by then
Apr 14, 2014 | Pentair Legend II Pool Cleaner
Fridge leaking intermittently from the bottom
Sounds like your gasket may be going out. Consider replacing the gasket on the doors. Look for signs like small lines of frozen water that lead to the door or unexplainable excess ice in the bottom of the freezer.
I would also check for excess water in the condensation catcher tray, which may very well be located in the same spot under the ice maker. Depending on where you live (southeast, coastal, etc...) can have a strong contributing factor of having excess condensation, which will cause the tray to overflow.
Apr 25, 2017 | Kenmore Refrigerators
Excessive "fog" in freezer causing
Check your door gasket. Cleaning the gasket should help it seal again
Nov 27, 2017 | Maytag Refrigerators
Water leaks out from the bottom of the case ... just about where the outflow pipe is located. Additionally, large amounts of water are going out the out flow pipe. I am getting more than 2 quarts of...
YOUR HUMI IS IN NEED OF MAINTAINACE. THE CALCIUM DEPOSITS ARE CLOGGING THE THE SPONGE ROLLER THAT WOULD NORMALLY ABSORB THAT WATER, YOU ALSO HAVE THE HUMDITY SETTING RATHER HIGH THATS WHY THERES SO MUCH WATER. THE TUBE THAT IS LEAKING IS MADE TO DRAIN OFF EXCESS WATER FROM THE ROLLER AND THE REASON IT LEAKS IS BECAUSE IT ALSO NEEDS SERVICE JUST PULL IT OFF AND CUT THE SEWELLED PART OFF WITH RAZOR OR CUTTING KNIFE IF IT IS PLASTIC TUBING AND REPLACE IT. IT SHOULD BE DRAINING INTO THE DRAIN ON THE FLOOR WHERE THE FURNACE CONDENSATE TUBE IS.
Mar 05, 2010 | Aprilaire 700 Humidifier
Hotpoint 18.2 cu ft refrigerator -water pooling on the floor
Was it the tubeing that drains the defrost water that you cleaned. Did you clean it at the top where it would be stopped up with ice. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If not
Aug 15, 2009 | Refrigerators
I have a 15 ft by 48 inch intex pool and i just
The most obvious thing besides not having salt in the pool has no stabilizer in it. This is a chemical that has an affinity for chlorine ions and if it is not there the chlorine can be disipated in a few hours when the sun hits it. Another name for it is Cyanuric Acid. It can be purchased in granular form at many pool supply stores or in a liquid form at Leslies. In order to get your pool blue you need to have the chemistry checked at a pool store or with a test kit (either liquid or strips). Don't buy everything a pool supply tells you to buy but start out with vinyl safe shock, stabilizer and salt. The pool store should be able to help you determine the dose. The following is what I would do:
1. Make sure salt is at the recommended concentration.
2. Shock the pool to recommended dose to start killing the algae.
3. Place the recomended dose of stabilizer in the pool.
4. Make sure pump and filter are working properly.
5. Check the pool chemistry on a daily basis until it is ready for swimming.
6. Check the chemistry on a weekly basis and clean the pool and equipment according to the pool instructions.
Smile, you are a pool manager.
Aug 10, 2009 | Intex Automatic Salt Water System for ...
Air conditioning water
there is a drain tube that takes care of the condensation from the A/C, these usually exit under the car, does yours must be blocked (do you get a pool of water when you stop in a parking lot? if not there is your answer.
Aug 03, 2009 | 1995 Nissan Maxima
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
True T-49 Side by Side Refrigerator Commercial Logo
251 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
