Question about Whirlpool Duet GHW9150P Front Load Washer
Door locked & nothing happens Whirlpool duet wfw8300sw01
I got this washer from a friend that didn't want to work on it. His cloths got stuck in the washer so he broke the door switch getting the cloths out. I replaced the switch & turned it on door locked & nothing happened. any help would be greatly appreciated.
  • 3 more comments
  • mtrman34 Sep 29, 2008
    I have never gotten a Code from teh machine I will try to leave it on for a while & see if I get one..
  • mtrman34 Oct 01, 2008
    hey Squishy2,
    I have replaced the door switch I have replaced the ccu I have unplugged all the wiring harness once I have looked for burnt & broken wires. I ran a test on it I got no error code It did come up with the light blinking at the Rinse/spin & that meant door lock issues..Ok So what else can I do I am kind of stuck.. do you think it might be a bad door switch (even though it is new) or a bad console..? So do you have any more ideas..? thanks for all the help...
  • mtrman34 Oct 02, 2008
    Thanks Squishy,
    I will make sure the door & all it's parts are tight. I was also wondering did I get a bad door switch even though it is suppose to be new.. I will look at it this evening & let you know what I find..
    Thanks for the help..
    Hi Squishy,
    I will check the door & make sure it is tight. I have been thinking I might have a bad door switch ( even though it is new). Do you think the console could be messed up..? The door locks as sson as you push the start button and then nothing happens...
    thanks for the help
  • screwturner May 11, 2010
    did the mach give you another code after a while?do you hear a humming noise? if you do make sure hot and cold water is turned on.sometimes you have to let it sit for at least 10mins for another code to show.
  • 409 Answers
sounds like the machine has no power at all.
there was no need to break the lock.
unplug the machine
take off the console
check connections from the touchpad to the CCU board
make sure nothing is corroded, burned, bent or pinched
unplug and replug the wiring harness
plug the machine back in and try it again.
let me know if this works.
Posted on Sep 30, 2008
  • Carmen Mikulic Oct 02, 2008
    hi again,
    i would check the door itself then before replacing the door switch again. make sure none of the hinges or door liner (metal panel inside of the door) are damages or loose. i have a suspicion that the door itself is not aligned because of the door lock.
    if all else fails,replace the door lock again.
    let me know how it goes.
  • Carmen Mikulic Oct 03, 2008
    start with the door switch first. i wouldn't go into the the more expensive parts until i know for sure that the door switch is working.
Duet front loader washer Model WFW8300SW01 Whirlpool. The washer is not working it locks the door when you press start. We have replaced the door latch and the main control board. At one time it had a F28...$FILE/8178558.pdf
This should tell you all you want to know.
Sep 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer is ripping my clothes
yep, I have that problem too. My son's winter coat got wripped to shreds.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The time remaining on the wash cycle is blinking door is locked
M duet was also haveing problems and when it would stop in a cycle it would flash a leter and a # F 02 I hit cancel and restarted it the time was all messed up I looked up the code for F 02 and found this page, I will post the link below. it was a drainage problem I cleaned out a trap in the pump really easy to do and it just might fix your problem. Regardless ever Duet owner needs to know this and matain this trap I pulled out a bowl full of stuck in it. Good luck!
Dec 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whilpool duet don't work and my clothes are stuck because the door won't open.
1. Unplug washer
2. Remove bottom access panel. (three screws along the bottom)
3. Reach up on the right side where the door lock is located, there you will find a release mechanism. Pull down and the door will unlock.
If you need further assistance, let me know
Jun 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet won't run
The trouble could be with the door interlock. When the clothes were jammed in the door it could have caused the door latch to put strain on the interlock.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Front Loading Duet Washer will not start
You have to set your programme FIRST, then put the "on" switch. Try.
Mar 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
233 people viewed this question
Dan Webster
Dan Webster
Sal De
