Question about Canon PIXMA MP160 All-In-One InkJet Printer
Feeds multiple sheets of paper at once
My Canon PIXMA MP160 has always worked flawlessly, but yesterday it suddenly started pulling in several sheets at once every time I tried to print.
Does it just need some kind of adjustment?
Thanks,
Troy
  • blueempiremc Oct 15, 2008
    My Canon PIXMA MP150 feeds all the sheets of paper at once. Cleaned the rollers with cotton and alcohol but still having the same problem. Any suggestions?
  • Canon Master
  • 4,338 Answers
This usually happens when "paper dust" builds up on the take in rollers. Clean the rollers with cotton and alcohol.
Posted on Sep 27, 2008
  • Jesse Mason Aug 22, 2014
    and when it's brand new and doing it already? with clean, flat, properly loaded paper?
Similar situation like that happens in commercial printing. It often relates to the paper/weather condition. Try to aerate the paper, change paper batch completely. Was there a sudden change in the ambient temp. or humidity ?
Marc
Posted on Jan 16, 2013
Canon mp160 paper always feeds skew, can the paper be fed from the bottom instead of the top thanks Peter
Solution obtained on cannon website-paper can only be fed from top(back).This is a common question as the paper tends to feed skew.
Feb 08, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My canon Pixma MP160 feeds too many sheets at one time. I have cleaned the rollers. It was printing beautifully not five minutes ago.
I recommend fanning your paper. Take the stack of paper from your input tray or feeder. Fan it like you would a deck of playing cards. This may help keep the leading edges of improperly cut paper from meshing to each other, resulting in feeding more than one sheet.
Dec 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jams on right side of printer
hi,
paper feed assembly allignment problem.
pls contact to any printer specialist for allignment.
Aug 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
When I click on PRINT, the paper feeds through without printing and there is a PAPER JAM message. There have also been feed problems in that the paper goes through crooked, although it was fed in straight....
The transport rollers are a slightly roughened rubber that gets less 'sticky' with age and the rollers become fouled with paper fibers that insulate the rubber from the driven sheet. Cleaning the rollers (on most, some disassembly required) may cure both problems but if you have ever done labels with the machine, you may have some residue of small piece of one in the wrong place.
Many of our (nearly disposable) printers are put together with molded snaps that must be pried upon to free them so it may be a daunting task for someone inexperienced.
Jul 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Auto sheet feeder does not load paper straight causing it to jam.
Normal 0 Worth a try:
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print buttonapplying a slight amount of pressure on the Card Stock so it will feed throughthe printer. The reason for this, in some cases I have been able to clearthe paper track of debris that was deposited there over time. Worth atry. I have fixed a number of printers this way saving costlyrepairs. Bud
Jan 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper Jam
clean the paper feeder gears. with some rough material.it will work properly.
Aug 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam
One of your jam sensors may be stuck in the actuated position by a paper scrap or dust, giving a jam code to your printer. There are usually two sensors, one where the paper feeds, and one where the paper exits. Try this: hand-feed a sheet of paper through the machines paper path,IN THE DIRECTION THE PAPER NORMALLY FEEDS. This may force out whatever is actuating the sensors.
Aug 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Mp160 printer
Sometimes these printers the roller that pulls the paper in doesn't have enough grip to it. If that's the case you need to clean it with a Q-tip.
They are also sometimes spring loaded to touch the paper and pull it in, so perhaps loading more than one sheet into the printer will help?
Jan 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper will not feed properly/one side of paper not feeding in straight
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
542
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
927 people viewed this question
old marine
old marine
Corne Viljoen
