Question about Lexmark X6170 All-In-One InkJet Printer
Faxing to a residence
Hi - I have a problem with our office Lexmark X6170 faxing to the CEO home office. It either constantly says "no answer." I had someone at the house fax within the house from their fax to the fax in question and they were able to. It seems from the office [off location] to the house offie there is a problem. Can you help?
thanks.
  • Lexmark Master
  • 4,338 Answers
It may be that your CEO's fax machine is not setup to receive correctly. Have someone check the fax receive settings. Have them set it ot fax only and automatic receive.
Please remember to rate all users who assist you for free :)
Posted on Oct 02, 2008
How to run a report from Lexmark X6170 fax
Please follow these steps to run a report on your Lexmark X6170. From the printer operator panel, press Fax to enter Fax mode > press Options repeatedly until Print Reports is highlighted. From there you can print an activity report, send log, receive log and fax settings list.
I hope this helps.
Nov 07, 2011 | Lexmark X6170 All-In-One InkJet Printer
I have a lexmark X6170. Running Windows XP. Recently installed Micorsoft Office 2007. When I double click on the desk top icon or choose to open the program through all programs, the all in one...
To scan, you probably have to use Microsoft Fax and Scan program. It works just fine with the X6170 ... it just took me all afternoon to figure that out.
If this helps you, please come back and vote Yes so that I know I helped someone. Thanks!!
Sep 10, 2010 | Lexmark X6170 All-In-One InkJet Printer
Can't receive faxes
Hello. Make sure you're plugging the printer to the correct phone jack in the wall. If you're using a splitter, bypass it. Check the settings in the printer. Make sure you assigned the correct Fax number in it and place your Fax name as well. If you're sharing your home phone line with the fax and you have an answering machine, set it to answer first and the Lexmark fax later with a minimum of 2-ring gap. If you have a voicemail, turn it off since it will a conflict with the fax or avail a distinctive ring feature from your phone company so it can work with the fax. Hope this helps.
Mar 23, 2010 | Lexmark X6170 All-In-One InkJet Printer
My Lex mark x6170 fax is beeping while faxing
I had the same problem, only with a HP Officejet 5610 All-in-One.It beeped for like 20 seconds and then said that there was no answer. Maybe you have the same problem?
Apr 08, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 Has a shared phone/fax line with different numbers
Open the Lexmark "Fax Printer Setup Utility". Click on the "Connection/Dialing" tab. In the "Interact with Phone Line" section, "Answer Incoming Calls:" should be set to "If fax tones are detected".
If this is turning out to be too unreliable for you, you will need to either manually receive incoming faxes (by changing the setting to "Manual"), or you will need to at least spring for a separate phone number with a distinctive ring for incoming faxes.
Apr 05, 2009 | Lexmark X6170 All-In-One InkJet Printer
I am trying to set my fax machine
Tried turning on the "auto answer" button on the control panel? :-)
Jan 06, 2009 | Lexmark X6170 All-In-One InkJet Printer
Receiving a fax on my Lexmark X6170
for these companies, try disconnecting the phone tremporarily to see if thsi is interferring just with these particular faxes. Sometimes if a company's fax is set to phone/fax, it may be trying to call you first beacuse ths would be the default settings. If it detects no phone it may by default accept your fax no problems. Hope this helps.
Aug 18, 2008 | Lexmark X6170 All-In-One InkJet Printer
Can't receive fax on Lexmark X6170
not really...some fax machines are not happy with receiving from a computer or printer(read that digital). may take years for it to work itself out.
http://tinyurl.com/6qcpgy
Have a Lexmark X6170 copier - lost our manual - need suggestions or solution
hi
you can try there web site at lexmark see if any thing here can help you.lexmark x6170
riz.
Apr 03, 2008 | Office Equipment & Supplies
How do I connect the wires for faxing?
there are two phone jacks at the back of the printer one is for line another one is for external device such as answering machine make sure you connect your phone line to the line jack at the back of the printer and try it should work. and also try to fax the right no.
Dec 12, 2007 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
