Question about Hitachi 53UWX10B 53" Rear Projection Television
A better pic
I have a hitachi 53uwx10b n it shows nice pics but i would like 2 get even better pics.. iz der any thing dat could be done or hooked up 2 it dat would help me get even better pics dat i could purchase??
    Novelist:
  • 100 Answers
Yes there is. You can buy an HD Disc player. There is two types out there, HD and Bluray. I would recommend Bluray because it seems like HD DVDs are falling off. So buy a Bluray player and Bluray discs instead of traditional DVDs, traditional DVDs will not put out in HD. Also, if you have cable, get an HD receiver and you can pick up the special HD channels. Good luck. If you need anymore help, let me know.
-Andrew Hawkins
Posted on Sep 26, 2008
HITACHI CP-X305 PROJECTOR SHOWING GREEN IN THE CENTOR OF PIC
the Polarizer glass (green) is broken ,you need a new a one
ny questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 17, 2014 | Hitachi Gst Hitachi CP-X305 3LCD Projector
Phillips tv stand by button stuck no sound r pic mod.no.42pfl9632d/10
the model is phillips and picture above is Hitachi--the philips is not customer repairable--call around and get a estimate.
Oct 17, 2012 | Hitachi 53UWX10B 53" Rear Projection...
Red on light flashing
The TV needs the convergence amp IC's replaced. Call a good TV Tech to replace them. Should be around $325
Jul 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
53UWX10B Convergence Problem
Had the same problem with so I purchased a repair Kit from www.TvRepairKits.com. The kit had all the parts and simple step by step pics of the repair. I cant thank them enough for making this possible . At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly. Try them
Louis
Jun 19, 2009 | Zenith R49W36 49" Rear Projection HDTV
53UWX10B blurred pic and blue/yellow lines
you can try the convergence first
if you cant converge the lines into one to correct this then you would require service for the convergence stage of your set
this is not a uncommon problem and usualy runs around 280 to 350 to repair unless the dcu is at fault
Jan 20, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Will Hitachi 53UWX10B 53 in. Rear ProjectioSupport play station 3
Yes, it will work. Be sure to use input 4 with the 3 rca input cables red/blue/green for video and 2 rca red/white for the sound. You need component video output on the PS3. http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&langId=-1&productId=8198552921665061579&storeId=10151&INT=M:ak is what you need, if you don't have it already. Here's the thing. The PS3 will work on any set. You can hook it up with the yellow wire and red/white wire for standard def. or 480i. The component cables are for 720 and HDMI for 1080. Your set don't have HDMI, it has component input. The service manuel say's it has 720I available. You can see if the front has HDTV sticker..if it does, them for sure it does. Either way, the PS3 will work on your set. I'm 90% sure it's 720i as well.
Dec 24, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Transferring photos from hitachi hdc-1061e digital camera to my pc running vista ultimate!
Sorry, I haven't been able to find any software, but you can try the following workaround:
1. Plug in the camera to the PC and ensure it is detected by the PC.
2. Right click START button and select Explore.
3. From the left panel, scroll to the drive corresponding to your camera. (It will usually be located after the last DVD/CD ROM Drive letter.
4. Click on that drive to expand the folders in the right pane.
5. Search for the relevant pictures from a folder within that drive.
6. Copy the required pics (Press CTRL and click on pics in case you want to select more than one pic.
7. Once you copied all the needed pics, select a folder on your computer (or create a new one) and paste the pics into this folder.
8. You're done :)
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 04, 2008 | Hitachi Cameras
High definition
Have you tried Video input #5?
Sep 20, 2008 | Hitachi 53UWX10B 53" Rear Projection...
53uwx10b,hitachi
dactag,
Working backwards now.......The burning smell will be the current limiting resistors near and in the circuit of the IC's
you changed..1 to 2 ohms, 1 or 2 watts.....caused by generic
replacement IC's STK392-110,120 or 150......Here is what to do to FixYa! First,please read some of my solutions for convergence
repairs...any brand,the info is generic,the repair parts are not....
1) REMOVE cheap IC's ! Replace with Hitachi part # CZ 01341
upgrade Mfr by Sanyo STK394-160
2)Replace any / all burnt or changed value resistors
3)Re-test to see any symptom....DO NOT CONVERGE
4)Think about putting the original DCU back,since it was
not the problem .......
5) Now where are we at ?? ............................T.
Feb 05, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi Ultravision 53"- went blank
If it popped, it may have done one of 2 things, the convergence amps may have gone out, or there may be something in the horizontal output section that is shorted, either way call the repairman.
Jul 07, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
67 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
