Question about Blaupunkt Car Audio & Video
Keycard error I have a Blaupunkt Woodstock DAB 54 head unit. I had to disconnect my car battery. I have tried to turn on my audio equipment after re connecting the battery but my securetykeycard has an error. Is there any way to get a replacement card or download the information onto another card?
  • 65 Answers
The solution is NO
Posted on Nov 28, 2013
2 Suggested Answers
  • 71 Answers
SOURCE: Blaupunkt car audio show error4
you can either leave the ignition on for 1 hour and hope it resets. or take your manual and radio information to peugeot they should give you the code.
try any of these as they may work depending on the model.
3728 1728
2256
Posted on Nov 28, 2008
I have a blaupunkt woodstock dab 54 and its stuck saying wait 1h HELP!
by default you have 3 chances to enter your code, after then time is get much longer for you to wait. what you can do is still keep your radio power on and leave it for 1 hour, Do not power Off. the cycle of wait will reset. then you can try enter you code again. hope its help.
Aug 02, 2014 | Blaupunkt Woodstock DAB 52 CD Player
My woodstock dab 54 reads kcard not ok after i changed the battery and wont let me keycode number
Hey I could do with help on this as I have lost the kcard (Ihave the code)
Feb 18, 2012 | Audio Players & Recorders
Intermittent bleeping on tuned - in -stations
You have the traffic updates on - I'm not sure the traffic function has ever really worked on the 52 but turn it off and you should lose the annoying beep. As an interesting but annoying aside, you won't find this info on the Blaupunkt FAQ page searching under 'beep' because they describe the noise as a 'peep'... go figure!
http://www.blaupunkt.de/index.php?id=882&no_cache=1&L=1
May 11, 2011 | Blaupunkt Woodstock DAB 52 CD Player
Hi, I have a Blaupunkt Woodstock DAB 54, where I don't have the Master Key Card. I can see that I can use a normal SD card, and enter the 4 digit master key again. But I dont have it. I can see that we...
Hi , try 7589 , not sure if it will work but its a maybe , i also have a dab54 and i got the key wrong 3 times , now its been stuck saying wait 1 hour for the past 8 hours , i think imma introduce my hammer to it , hope the code helps :)
Apr 30, 2011 | Car Audio & Video
Problem for Blaupunkt Bermuda MP36 Car CD Player. I was getting the error CD error when I use to insert the mp3 cd in the CD player. I complained and was asked to reset it by disconnecting the battery...
The fault was explained earlier, please check your MP3 format. play a normal cd to see if it detects, if so try with another recognised MP3. if not clean your head after opening the set. try again or it is possible that your optical is faulty or the RF signal processor IC is defective. Check this out. Good day
Jul 12, 2010 | Blaupunkt Bermuda MP36 Car CD Player
Hi, I just bought a blaupunkt Sydney RCM 126. After connecting the unit to my car, the display says ''wrong KC''. It has been working ok with the previous owner. Obviously after being disconnected for a...
Wrong KC means wrong keycard (smartcard)
This radio requires a Keycard (Smartcard) in order to operate.
See explanation here
http://www.bluespot.co.uk/keycard.asp
Nov 10, 2009 | Car Audio & Video
Cd shuttle ejects when power to head unit is turned on
Hi Adam,
Since you've been trying things for so long, you may not mind another, unless you've tried it already.You'll need someone to help you.
Try using a volt meter on the main power to the changer. (If the changer is din mowered only, this can't be done) and when toy power up the head unit by ignition or other method, read the voltage on the main power wire (yellow?). Tell me what it shows. Also, the "turn on" wire for the unit is usully in with the data cable to the unit, and won't be able to check that.
Also try to read BOTH the acc AND the power wire on the head unit while turning on.
When you read the voltges, make sure that you use the ground ON THE CHASSIS of the componant that you are checking. "Maybe" you have a voltage variance like you said d to a weak ground at one of the units? I'm just troubleshooting as I would if you had brought it to me. Let me know again. Thanks.
** Note- Have you actually reset bothe the head unit and changer?
Larry T
Winona Lak, IN
Jan 27, 2009 | Blaupunkt Louisiana DJ32 Cassette Player
Blaupunkt woodstock 54 has a mind of its own...
Hi
Ive got the same unit & they can be a bit unpredictable.Theres a way around it as the unit facilitates a 'NORMSET' feature which allows the user to reset the unit to basic settings as when it was first taken out of the box.
Also the sd card you use can only be 1gb or less & has to be formatted in 16kb through windows XP or Vista.
If you want to know more get back to me & I will talk you through it,it sounds like the units been corrupted by a sd card that wasn't formatted correctly as this happened to mine but now is sorted.
The WOODSTOCK Range aren't made anymore,the latest version is the NASHVILLE,and I was advised that my unit may have had to go back to Germany for reprogramming as no-one really knows about them in the UK.
However I sought advice and problem was rectified.
Mar 21, 2008 | Audio Players & Recorders
Car Audio & Video Logo
307 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
