Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Load Washer
We have a long haired cat, so our clothes have cat hair on them when I put them in the washer. Someone mentioned that I should check, and clean the filter on the drain. Where is this filter, and how do I get to it?
  • 5,911 Answers
The following link will explain to you how to check the drain pump filter on a Whirpool Duet:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance Good luck.
Posted on Sep 26, 2008
Whirlpool front load washer model WFW9050XW00 - Machine stopped still loaded and with door locked. I was able to unlock and remove clothes leaving water and heavy suds. Tried running drain-spin and...
Your pump is jammed with a blockage, remove the filter and check the pump behind it is revolving, usually a hair grip or button in there...remember the washer is full of water so you will have a lot of water coming out
Sep 05, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Front Load GLTF2940 full of pet hair
Why dont you shake out the maximm hair before loading into machine?
Apr 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dront loader washer
Welcome to Fixya,
Try this,
The manufacturer recommends unplugging the washer for at least 30 minutes. This will often fix momentary glitches with the washer.
Let me know,
Huuum
Please remember to leave a rating
Oct 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool basic top loader
since you can not get the washer to run if you plug another item into the recepticle will it work use a hair dryer to test if the hair dryer works then the receptical is good and you have a washer problem if the hair dryer does not work then you have a wiring issue on the house wiring
May 09, 2008 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
CLEANING OUT CAT DANDER ETC FROM WASHER
Quenie, vinegar will not harm your washer at all. Place it in the detergent side of your dispenser and run a Hot wash cycle. Don't mix chemicals, though... if you choose to clean your machine with bleach, for instance, don't use additional cleaners along with it. Vinegar only, bleach only... you get the point.
You may want to run a "water only" Hot wash cycle with bleach (no clothing/towels) after your Son has finished his laundry. This may help alleviate your allergy problem.
For regular maintenance on your washer, you ought to try something like this. It'll keep your washer smelling great.
Nov 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Liquid Bleach dispenser doesn't work correctly
This may not be relevant, but by design, bleach does NOT dispense in the Buly/Bedding, Kids Wear, and Silk/Ultra Delicate cycles. If you try to use it, it remains in the dispenser.
As for the yucky smell, leave the door open when not in use.
Nov 16, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
260 people viewed this question
Dan Webster
Dan Webster
Sal De
