Question about Canon imageRUNNER 5000 Copier
NIC I just replaced the NIC on the Canon Imagerunner 5000. I'm getting error code E000740-0003. Please help, thanks. Al
  • Canon Expert
  • 270 Answers
The error code is for a bad NIC board. Are you sure the new board is good? I would try to put the NIC board in another copier just to see if it's good. I've never had any problems putting in the NIC board and it not working. What was your oringinalproblem that you hadto replace the board in the first place? The main controller may be bad also. Good luck.
Posted on Oct 17, 2008
Error 003 in canon IR 5000
A E003 is a error code with the fixing unit. I would first try to reset the error code in service mode first. If that will not correct the problem, most likely the thermistor will need to be replace. The PCB connection break off. I would replace the sub thermistor at the same time. Good Luck
Dec 23, 2012 | Canon imageRUNNER 5000 Copier
There is an error in our canon imagerunner 5000 M/c.
clear problem description is half of the solution. please describe your problem clearly ,thanks.
Jan 04, 2011 | Canon imageRUNNER 5000 Copier
I have an error 00315-00d...can u help me to fix it...in canon image runner 5000...thanks a lot
hi;
you mean E00315-000d-00
this error code appears when there is a codec error the solution is :
1) replace the SDRAM
or
2) replace the HDD
or
3) replace the main controoler board
Oct 04, 2010 | Canon imageRUNNER 5000 Copier
Error Message E000001-0000
its a fuser error high temp or lower temp
try to rest this error in *28* FUNCTION,CLEAR,ERROR then on off the machine
if the error the same try to replace tem sensor
Oct 28, 2009 | Canon imageRUNNER 5000 Copier
Our Canon ImageRunner 5000S shows the Error Code E000003-0000
this error is related to fixing unit,to reset error:* with head 2&8 together* with head LCD display change press COPIER> Function>Clear>Err>OK switch off/on the machine,if the error return check the AC supply unit or you have to call your service provider
Jul 22, 2009 | Canon imageRUNNER 5000 Copier
Canon imagerunner 6000 troubleshooting error e000061.0001
i have a problem E0001-0000 & e0000-0003 please solve my problem
Jul 10, 2009 | Canon imageRUNNER 5000 Copier
Hello can you really help me solve the error code that i getting on my IR 5000 the code is E000012-0000
That error means that you have a problem with the drum motor. Check the it's connectors. Or maybe something keeping the motor from running, like an uptwisted blade with drum.
Dec 25, 2008 | Canon imageRUNNER 5000 Copier
Help me.....faster....
Errors commencing with E3---- means that something to do with the reader unit,,,, apart that error mentioned does not exist. If youhave plenty of parts that you can try out I will try to replace the reader board....
Dec 15, 2008 | Canon imageRUNNER 5000 Copier
E000001-0000 error code
it s a thermistor problem
to clear the error do the following.
press additionel functionel* button & press 2&8 at a time &press additionel functionel button* select COPIER>FUN CTION>CLEAR>ERROR>OK.
Aug 06, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
103 people viewed this question
old marine
old marine
