Question about GE 24 in. GSD4060JSS Built-in Dishwasher
Cleaned out hose next to garbage disposal found a little dirt but still not draining?
Clean out the air gap. Remove decorative cover by pulling up. Remove plastic dome by gripping and moving side to side while pulling it up. When you get the dome off you can see if the air gap is partially blocked.
Posted on Apr 21, 2009
Jan 02, 2015 | Dishwashers
Dec 17, 2013 | Kenmore 15129 Built-in Dishwasher
Dec 14, 2012 | Badger 5 Insinkerator 76037h 1/2 Hp Feed...
Oct 08, 2012 | Dishwashers
Sep 27, 2012 | Kenmore 665
Mar 31, 2011 | Whirlpool Dishwashers
Feb 27, 2011 | Bosch 24 in. SGS43C12 Classixx...
Will the dish washer spray water during the wash cycle? If no it could be the pump motor. The motor will run in the opposite direction to drain the washer. If it spays water it could be a clog in the drain hose or the connection to the drain (on newer units) or garbage disposal (on older units). Remove the hose from the drain and place it into a large bucket to see if it drains during unit operation (stop the washer if the bucket fills). if it does clean the connection to the drain or the garbage disposal hole. If not make sure the hose is free from obstructions. If the above checks out then check for voltage on the pump connection with a volt meter. You may be able to visually inspect the pump or listen for the vibration of the pump during the draining operation. If you have voltage the pump is defective or the internal garbage disposal (found on newer units only) is clogged or damaged.
Jan 13, 2011 | Dishwashers
Sep 01, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
145 people viewed this question
