Question about Sony Walkman Sport Series NW-S205F MP3 Player
Can't open the Sonicstage software?
I followed the instruction per sony support to install the Sonicstage 4.3, but one Dialog show me :
The selected music file cannot be played back because the system information has been changed.
Click OK automaticlly close the Sonicstage and open the sonicstage system information restore tool.(ERROR CODE: 0004e2e)
When I click Ok, another dialog: authorizing,then blank.Still it does't work.How will I fix it? I try many times.
  • ldm2006canad Sep 29, 2008
    change the Windsows System to Win XP.Reinstall the SonicStage 4.3, then the problem is solved.
  • eskimo48 Feb 09, 2009
    I have the exact same problem using Window's Vista with error code 00004e2e, heading shows Sonic Stage 00000908-6736. I've tried reloading several times, and removing, clearing out files, and changing the folders for saving data. Also tried Windows XP compatability mode. None of this works.
SOURCE: error code:00007180
I have this problem too. Found that if you go to the folder that has the music file in it, right click on each problem file and select 'open with -> " and choose Sonic stage, then it will import the file. Next problem may be that it imports it with 'unknown' as the file name but if you then right click on the file within SonicStage and select 'Get CD info' it will find it. Tedious if you have several dozen/hundred files that won't import I'm afraid...
Posted on Jan 01, 2008
  • 242 Answers
SOURCE: problem with sonicstage software
Try downloading the newest version of SonicStage from the website.
Select your Model and click the blue button.
That one supports Vista.
Posted on May 21, 2008
adzboxer123
  • 8 Answers
SOURCE: SonicStage won't open
Hey i dont know if it can be fixed so i would jus remove them prgramme for you computer and reinstall it then it will be as good as new no problems,
Posted on Jul 16, 2008
SOURCE: SonicStage error message upon opening software
had same problem, but it's easy to solve. When you use vista and sonicstage 4.3 (vista version)
the only thing you have to do is to go to the propertiesscreen en turn off the compatabilitymodus with xp en it will run fine.
Posted on Sep 28, 2008
my sony walkman mp3 player model # NW-EO15F i cannot upload any songs, i wanna upload songs. but i don't know how to upload songs.please can you tell me.
Posted on Feb 03, 2009
I had my sony walkman nwd-b103f. when i connect it to the pc it say's usb device not recognized. plz help?
Please try these steps:
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
Thanks.
gylacz
Aug 25, 2011 | Sony Walkman NWZ-B103F MP3 Player
Tip
No Data/Format error on Sony Network Walkman
Sony Network Walkman does not support adding / removing of files, or formatting if it is not done from SonicStage, their software.
If music is added of removed from windows explorer or other software, the player gives an error message 'No data' or something similar.
To fix the problem, download and install SonicStage from Sony support website.
Select your model and click continue, then scroll down, select your operating system in the select box to the bottom of the page and select the software you want to download...
After installing, connect the player to your computer and select 'format' from the menu (This will remove all data from the player, so you might want to make a backup).
Now transfer your music files to the player using sonicstage.
Good Luck
on Apr 01, 2008 | Sony Network Walkman NW-E005 MP3 Player
Hi i m deep chhetri 4m nepal. my sony nwz-w202 dont show while conect to pc . when i formate device,then this problem device driver software was not instal successfully
If your pc has windows xp sp2 or later and Windows Media Player 11, please try this procedure:
I hope this will help you.
Thanks.
gylacz
Aug 02, 2011 | Sony Walkman NWZ-W202 MP3 Player
I purchased SOny NWZ-S544 Walkman. when i connect it to my laptop (Windows XP OP) it will not show up unlike other device, so i cant access it through my laptop pls help
If you have problem with your device follow this steps:
I hope I could help you.
Thanks.
gylacz
Aug 01, 2011 | Sony NWZ-S544 Digital Media Player
My sony nwz-b152f is not accepting .i need adriver for that
Good work and luck!
gylacz
Jun 24, 2011 | Sony Walkman NWZ-B142 MP3 Player
Need driver for Sony walkman NWZ-B152F
Thanks.
gylacz
Jun 06, 2011 | Sony Walkman NWZ-B142 MP3 Player
I am not able to install songs. i have installed sonic stage software. it detecting the player. after disconnectiog and playing, it shows no playlist.
The issue happens as the songs transferred to the player is not using the SonicStage Software. I suggest that you backup the songs in the Computer and then Format the Player. To Format the Player; press and hold the DISPLAY/HOME button, select Settings-->Advanced Settings-->Initialize--> Format-->OK.
Once the Walkman Player is Formatted, install the latest version of the SonicStage Software in the Computer and transfer the songs again using the Software to the Walkman Player. Click here to install the latest version of the SonicStage Software.
This should resolve the issue.
Thanks for using FixYa.
Apr 06, 2011 | Sony NWS706 - 4GB Walkman MP3 Player -...
I have lost cd for my sony NW-E002 so i cant transfer any music from my laptop to my player what can i do
google sony sonicstage and your operating system. This should bring up the sony site with a download link to the right sonicstage version
Oct 11, 2009 | Sony NW-E002 MP3 Player
I don't know if this will help but have you tried Sony's website? There is a security update for Sonic Stage 4.3 that they say must be installed in order to make the program run properly. Go to Sony USA and type in minidisc players in the search window. Then click on the link for minidisc players. When that window opens type in your model number and the page displaying that particular model should open. There you should find the latest software updates. I downloaded Sonic Stage 4.3 along with all of the needed updates from Sony's site and it works just fine for me. You may have to uninstall your current software and reinstall it after installing the security update as the installation instructions on the website said that the installation must be done in that order or the Sonic Stage software may not work properly. Sony also offers email tech support.
Good luck.
Feb 23, 2009 | Sony Net MD Walkman MZ-NE410 Recorder
Problem with sonicstage software
May 08, 2008 | Sony Network Walkman NW-E005 MP3 Player
Sony Walkman Sport Series NW-S205F MP3 Player Logo
2,080 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
