Question about Vintage Keeper VP110 Wine Cooler
VintageKeeper WineCooler After working for a while at setting of 55, it appears to freeze up (as ice crystals form on the vents of the refrigeration unit) and it stops cooling. This may be totally unrelated to the problem, but several years ago the water drain tube would drip water, sometimes quite a bit. We added a jar and eventually the tube sealed itself. Few months back it started leaking again and then ultimately quit. Any help? Thanks, Sandy
2 Suggested Answers
  • 400 Answers
SOURCE: My unit dripps from the tubing, front fans and back pannel
Usually there should be a drain pipe connected to the back end of the unit and long enough to remove the water from the room to a suitable drain point. You should see that this is installed. If so, then check that the existing drainage outlet is not blocked. You should also make sure that all filters are clean.
Posted on Nov 04, 2009
Samsung refrigerator is freezing up on back panel of refrigerator . Will defrosting the whole unit do any good? The unit is 2 years old
well yes and no , defrosting it will temporally make it work , but main problem is there isn't proper air flow over evaporator coils id clean them with soap and water while defrosting out unit , if low airflow is allowed to continue then refrigerant gas will build to high press and escape and render unit a total replacement
Sep 29, 2016 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
Ice crystals are forming throughout my bottom freezer
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 15, 2011 | Amana ABB1927DE Bottom Freezer...
MODEL # 59673504203 DRAWER IS ALWAYS FREEZING EVERYTHING IN IT. NOW NO ICE IS BEING PRODUCED
I had the same problem. I pulled the drawer all the way out. In the back is a vent flap. Ice had formed on it keeping it open. I chipped off the ice so the flap can move. This stopped the freezing veggies.
My ice maker stopped working. It was suggested I change the water filter as it may be clogged preventing water moving to the ice maker. As I am getting a new refrigerator I all not be buying a new filter.
This message is little late for the original poster but may help someone else.
Aug 04, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
My GE side-by-side has 2 problems, maybe related?
i have a 29 sidexside Ge refrigerator. tonight when i was trying to get ice,it stopped working and after a few seconds,with a clock like sound it began to work again.but everytime i try to get ice it happens again.last year i chanege the board. what is the problem,can i fix it?
Jun 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
Vintage Keeper VP110 Wine Cooler Logo
Top Vintage Keeper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Vintage Keeper Refrigerator Expert? Answer questions, earn points and help others
