Question about Dual Electronics CECT P168 Cellular Phone
Speaker volume When I call I can't hear the other person well, even tough the volume is set to full.
  • abrams7056 Oct 31, 2008
    cant hear caller they can hear me
Kindly check the MUTE ON/OFF option, if it is turned on , make it off and check , if still not getting the voice the the problem is in hardware part like the speaker is damaged, you can check this by switching on the call on speaker phone.
Posted on Sep 26, 2008
Very low volume on an Alcatel one touch pop4 phone.All volumes set at max and still low volume.Can I do anything?
as a person with below good hearing I have begun using my speaker phone full time so I can hear what people want to tell me . perhaps a bluetooth would work for you .
Aug 02, 2016 | Alcatel Cell Phones
How can I reset the volume control? All of a sudden, I can barely hear with the volume set at max.
You do not mention the type of Motorola radio so this answer will be general. You may have a problem with your volume potentiometer, Receive (Rx) sensitivity, or a speaker problem.
The volume pot on a 2-way radio is a common failure item, and will after repeated use possibly fail, or get dead spots. Try backing off your volume to 75% and see if it is louder at this setting. If so, you have a bad volume pot.
Rx sensitivity can be caused by various internal problems with the radio,and some models are more prone to this than others. Operating your radio at full volume most of the time can bring this issue to the forefront. (Tip: Try running your radios at 80-90% volume vs. full volume to alleviate this problem.) If this is your issue, your effected radios are in need of repair. Most repair facilities (including ours) can correct Rx sensitivity in most models during a repair.
Speaker problems: If you work in an environment where dirt, debris or metal shavings can get inside the speaker, your speaker may fail over time. Or if you run your radio at full volume the majority of the time it can cause your speaker to fail.
Best regards.
Oct 13, 2014 | Motorola Walkie Talkies 2-Way Radio
Ihave purchase of emachine note book of acer. volume of the speaker is so low hat even one person can not hear.i have talk with service center of acer,but they told that this is a maximum volume of the...
I have had that laptop once and had the same problem. I knew that it was the maximum volume of the speaker so I purchased external USB speakers to connect to the computer and the sound was clear and loud enough to hear anything played on the computer.
Thanks
P.S. Please rate if this solution was helpful
Nov 01, 2010 | Acer Computers & Internet
I can only hear the person I am talking to through headphones, I want to hear them on my speaker
To solve this problem ,do this; goto start menu >control panel>sound and audio devices
in volume tab under speaker settings , click on "advanced" in speakers tab speaker setup:select desktop stereo speakers
click performance tab Hardware acceleration =full sample rate conversation quality=best. click on apply,and ok
select audio tab in sound and audio output. click on volume ,unmute all . increase all volume to high. close it.
select voice tab in click on volume ,unmute all . increase all volume to high. close it.
click on apply and ok.
then open your audio manager .increase play back volume and unmute all .
important :select default device (sound play back) .to your audio manager's default device . after apply all settings .click ok and close it. in sound and audio output. tick on "use only default devices". . do it and solve it
Sep 08, 2010 | Skype IM
No webcam sound
The problem is probably in their set up, unless your speakers have a problem - you do have speakers?
Your webcam has no bearing on their broadcast or audio - in fact you can still see and hear other contacts even if you have no webcam installed yourself.
Check your speakers
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
If you have a desktop and no speakers fitted buy, a set of headphones for your chats
Jul 28, 2010 | A4tech PK5
Can only hear on speakerphone
This speakerphone is a separate speaker from the handset speaker, so if you can't hear through the handset and you have ensured that the volume in your profile is set up to max, then I would have to say there is something wrong with the handset speaker.
Hope this helps,
Bill
Sep 03, 2009 | RIM BlackBerry Pearl 8100
VOLUME
Without knowing what you're listening to, through what software and how your soundcard is set up this is tough. Is there a Karaoke application in this equation?
Oct 18, 2008 | Harman Kardon HK695 Computer Speakers
I have a problem with 6610i set that I can't able to hear other person's voice -
This sounds like the speaker in your handset which transmits sound to your ear is either faulty or turned down. Check the volume on your handset is set to max.
If the speaker in the handset is faulty - to trouble shoot this try using a handsfree kit which plugs in to the bottom of the phone and if the ear piece works correclty on a call through the handsfree eairpiece then your phone may have a fault.
Please dont forget to rate..
Jul 16, 2008 | Nokia 6610i Cellular Phone
Incoming call
Seems your ear speaker has a problem. It need to be changed.
May 27, 2008 | Motorola Mobility RAZR V3
Dual Electronics CECT P168 Cellular Phone Logo
47 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
