Question about Epson ACULASER CX11NF All-In-One Printer
HAVE EPSON CX11NF WITH SERVICE CODE FLASHING
WHAT DOES SERVICE REQ. C0083 MEAN
  • Anonymous Oct 02, 2008
    The same problem, with an epson epl-n2050 laser printer
You need a new photoconductor
Posted on Nov 05, 2008
Error service req E511, all lights flashing
Possible parts that caused the error
1 Photoconductor Unit 2 SENSOR TR-0
3 HARNESS-ASSY XERO 4 MOTOR ASSY P/R
5 HARNESS ASSY MAIN 6 PWBA MCU
7 LV/HVPS
Dec 28, 2009 | Epson ACULASER CX11NF All-In-One Printer
What means service 82 on aculaser cx11nf
Service Req C0082 CPU error (TLB miss exception [Load/Fetch]). Generally it is an envirnmental problem. Power the printer off and disconnect all cables. After one minute reconnect the power cable only and power on.
Then try a Starus Sheet, press the right arrow button 3 times. If the sheet prints then the problem may bea the network or corrupt documents been sent from the Netwrok or PC.
If the issue remains then you will need a new part so you will need ot contact Epson for further assistance.
Dec 21, 2009 | Epson ACULASER CX11NF All-In-One Printer
Service req E537
E537 is a Fuser Unit error, it most likely requires replacing but first try a few simple checks. Lift the scanner unit upwards out of the way and open the top rear cover to expose the fuser unit. Check that it is seated properly and that both "latches" are in the locked position. Try unlocking them and removing/reseating the fuser (there is a small plastic hinged piece on the L/H side of the printer that needs lifting to allow removal). If all of this fails you will need to replace the fuser unit. A google search should turn up a stockist in your area as they are listed as consumable items.
Please take a moment to rate this solution. Thanks.
Mar 20, 2009 | Epson ACULASER CX11NF All-In-One Printer
Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Feb 18, 2009 | Epson ACULASER CX11NF All-In-One Printer
ADF Jam... Service req c2011
Can be a tough one.
1st - Open the ADF & make sure that the 2 little Sensor tabs move freely.
2nd - Lift the ADF & check that the White Plastic Paper Guide is "down in the slot" & not resting on edge of the white flat bed scan pad or overlapping the scan pad.
For some C Error Codes
Check for electrical interference from external devices.
Disconnect the Printer from all devices, and run a test print..
Here are the "c2011 error" fixes per the manufacturer:
Replace the Automatic Document Feeder.
Replace the Scanner.
Replace the Main Board.
You might try unplugging the ADF & see if you can operate without it.
If you unplug the scanner, the printer might not function.
Jan 27, 2009 | Epson ACULASER CX11NF All-In-One Printer
C1100 service req e527
Hi-
Try reseating the Photoconductor unit, or for step-by-step instruction to resolve this call 562-276-1300.
Hope this helps
Oct 29, 2008 | Epson ACULASER CX11NF All-In-One Printer
Service req E527 error thank you it helped - the cartridges are still difficult to manouver - do you know if the plastic strips (with sticky tape) are meant to be there or not?
I imagine not. Usually, those sticky plastic strips are there for shipping purposes. Where exactly are the strips? Knowing that will help me advise you further.
May 24, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF All-In-One Printer Logo
647 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
