Question about Konica Minolta bizhub 250 All-In-One Laser Printer
BIZHUB C250 When I try to scan to my computer it tells me that "Cannot connect to the network"? I am working with a wireless system. Any Ideas?
  • 167 Answers
You are not getting a strong enough signal for the MFP to send the infomation over.
It needs to connect securely so as not to lose any data during transfer.
If it does not find a strong enough signal it will act as if there is none.
This is different when sending TO the device as the connection is being determ ined more by the network and it is more forgiving/can recover lost packets better.
Posted on Oct 09, 2008
Wireless network
http://www.konicaminolta.eu/en/business-solutions/support/download-center.html
This is the link foe every operating system for konica minolta, you just should select your working machine.
As for wireless please be ,ore specific what you should do because c250 has not an option in itself for wirless connection.
Jan 27, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C250 won't print or scan. Checked IP address on bizhub, and it is as always (192.168.1.100). Reinstalled Print Drivers (PCL6, Ver 2.53) but didn't change. Ping gets no response....
Your first priority should be to put it on the network , for this u should give the printer the IP 192.168.2.XX where XX varies from 4-99 . Please make sure that no other device should have the same IP which u are assigning it to the printer and and try to ping on the network.
Jan 31, 2011 | Konica Minolta bizhub C250 All-In-One...
How do I synch up the C250 scanner with my computer?
Hello.
There is a USB port to connect the C250 directly with a USB cable. Then, install the C250 driver on your computer with the CD that comes with your C250.
Hope this helps.
Jan 18, 2010 | Konica Minolta bizhub C250 All-In-One...
Scanning large documents to PDF takes a long time
Try to use Compact PDF or a lower resolution.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 14, 2009 | Konica Minolta bizhub C250 All-In-One...
Can't Scan anything on a BizHub C550 to 5 pcs on the same network
Be sure that your Domain name is in the network settings on the printer. This can be done on the printer itself or opening a web browser. Put the IP address in the address bar of the browser, this will conect you to the machine. Log off the public domain that come up and log on the administrator area. Enter the password 1 2 3 4 5 6 7 8, unless it has been changed. There you will be able to set all of the network functions. The machine need this information in order to direct the scans to the correct place.
Jan 06, 2009 | Konica Minolta bizhub C250 All-In-One...
Won't print over network
if same thing happened with c450, then i guess, that the problem is in the network. does the printer answere a ping, also you can ping from printer to network. maybe youll find something. but last option is that you have to upgrade firmware or change network board, also check network settings from printer.
Apr 18, 2008 | Konica Minolta bizhub C250 All-In-One...
Cannot scan documents on Konica C250/C250P
Hi, If it is set up as a network printer, then go to administrator settings & check the IP address of the machine.
Jan 16, 2008 | Konica Minolta bizhub C250 All-In-One...
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Dec 12, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
300 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
