Question about Sub-Zero 690 Side by Side Refrigerator
Refrigerator not getting cold
Yesterday i smelled something funny in my kitchen, later that evening Iwent to my freezer and the ice was melting, no other explanation, please help
    Problem Solver:
  • 8 Answers
Chech blower fan POSSILE Burned UP clean coils see if fan works, or check compressor in supper HOOOT, possible burned.
Smell , does it smell like like burming tar or burned food.
Posted on Dec 11, 2008
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
There was a burning smell in my kitchen yesterday, later in the day I noticed that there was water pudding on the floor in front of the unit. Later I noticed that the ice maker wasn't working and that my...
Probably so. I would be looking at compressor and the relay / overload that plugs into the side of it. Hopefully you are lucky and it's just that relay / overload that's bad and not the compressor or a control Board. Be sure to unplug unit before servicing. Once you remove relay / overload from compressor, shake it vigorously. If it rattles, it's bad.
Aug 28, 2017 | Amana BCI21V1C Bottom Freezer Refrigerator
Ice tastes funny and a strange metallic or plastic type smell
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
Jan 15, 2009 | KitchenAid KSRS25IL Side by Side...
Freezer cold/fridge not
take back plate off inside freezer and see if there is ice build up on the pipework. if so, this prevents airflow and the fridge is affected first. melt off ice with a hairdryer and restart.
if fault reoccurs, you have a fault with the defrost system
Aug 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE refrigerator not cold enough, again!
I emptied the freezer, unscrewed the freezer floor, pushed it out of the way, and saw the ice, just like last time. So I poured hot water over the ice, made sure the ice was all melted, even from below (under refrigerator), and put the floor back in - works fine, for now!
Jul 13, 2008 | GE PTC22MB Top Freezer Refrigerator
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
The freezer is working the frig isn't
YES , you need to replace the thermostat timer,its a device that operates like every 30 min or so applying heat thru a black element to keep the freezer from not building up ice . hope this helps AJ
May 12, 2008 | Amana ABB1927DE Bottom Freezer...
Sub-Zero 690 Side by Side Refrigerator Logo
472 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
