Question about Samsung SN-S082D DVD RW Dual Layer Burner
Dvd player {4D36E965-E325-11CE-BFC1-08002BE10318} The dvdplayer in the laptop doesnt work anymore, it doesnt see the cd or dvd. I did the trick of removing the Upperfilter, and restart that did not help either. There was no Lower filter to remove. I suspect the problems were caused by Nero 7. I use Vista, everything is newly installed and updated.
    Novelist:
  • 119 Answers
Try updating the driver for your player that supports windows vista. if the player is not detected in your vista but detected in your bios try updating your bios as well. or you can try to do a system restore by going to start all programs accessories system restore. choose a date which you believe your player to work fine.
Posted on Oct 08, 2008
My dvd player is not recognized by my computer anymore.
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Jun 04, 2012 | Pioneer Bd-rom Dvd±rw Laptop Drive...
Ive put photos on dvd from my laptop, how do i finalise the dvd to play on other dvd players.
if you have just copied the photos to the DVD as a data file then just insert the DVD on the DVDplayer and just press play and it will slideshow the DVD...
else you can use any free " photo DVD creator " and use that to create the DVD and watch it on DVD player.
the best is Nero photo DVD/CD creator....and it's free
Apr 27, 2010 | Computers & Internet
Cd player wont work!
In the run box type regedit, go to HKEY LOCAL MACHINE - SYSTEM - Control Set001 - Control - Class - {4D36E965-E325-11CE-BFC1-08002BE10318} - On the right hand side check for upper or lower filters if you find one delete it.
Do the same with Control Set002 and Current Control set.
Restart the computer, if it still doesnt work then open device manager by rt click my computer- properties - hardware- device manager - uninstall the cd dvd drive and also ATA Channel 0 and ATA Channel1 restart the computer .
If still issue is not resolved then reseat the dvd drive.
best of luck
Apr 13, 2010 | HP Pavilion dv6000z Notebook
Dell laptops cd dvd drive not working
check the device manager if the cd / dvd driver is listed if not then try to reinstall the driver software for the DVD/ cd drive, if that doesnt work try this
try this one:
if you are using windows XP
- click start
- click run, in the run type in regedit
you will see a registry editor window
in the registry editor window
- click the + sign at the hkey_local_machine
- click the + sign of system
- click the + sign of currentcontrolset
- click the + sign of control
- click the + sign of class
there will be bunch of random letters and number under that control
try to find this one
if you click this check if you will be able to see DVD rom at the right side of the registry editor window
you must delete the upper and lower filters
after that restart the computer and try to put in dvds
for vista or win7
- click start and type in the start search regedit
after this just do the same thing with the win xp instructions
try also to update the DVD codec. you can also try to download the most updated windows media player, power DVD or any software/program that have dvd codecs or that acts like a player for DVD
i hope this works.
Pls rate my resolution thanks!!
Mar 05, 2010 | Computers & Internet
My portable dvd doesnt play dvds anymore
Try cleaning the laser with a cd/dvd drive cleaning disk. if this dosent work you will probebly find the laser has broken
Dec 01, 2009 | Philips Televison & Video
Toshiba Satellite laptop no longer sees DVD drive
Goto start -> run ..... type regedit
hit ok.
goto the following registry setting
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Look to the right and delete the following
"UpperFilters" and "LowerFilters"
Close regedit and restart PC. If that doesnt work then the dvdrom is bad.
Sep 11, 2009 | Computers & Internet
My dvd was deleted from my laptop. I need a dvd player replaced
if you insert the CD movie files go to My Computer icon then click the DVD player icon and open or click double the icon of DVDplayer then if you see the folders of CD movei click the folder name Mpeg then click open with Media Player...good Luck and Have a Nice Day...
May 28, 2009 | HP RT865UTABA - HP Promo dc5700 micro...
My dvdplayer wont playdvd
Try a different DVD If that doesnt work then try a music CD. If that dosent work then in sorry but the laser Mechanism has gone bad and it would cost more to repair the DVD player then replace it.
Thanks for reading!
Apr 22, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD moves
you can play dvd in media player but you have to tell media player what files it should play.you also need to make sure you have the cudecs.you can configure media player to connect to web to download codecs it may not already have for various media formats.
Jan 10, 2008 | Acer TravelMate 2201LCi Notebook
Dvd decoder
YOu need a 3rd pary dvd player software installed, Like power dvd. Power DVD , Win Dvd etx, you should have gotten a copy of a player when you brought your computer, If you didnt or cant find it you can download one, many have trial versions or you can get a free one.
If you get a trial version of Power Dvd it automatically installs a dvd decoder. even if power dvd trial expiers and you cant use it anymore you will still be able to play the dvd's on windows media player cause the decoder will remain there and media player will have axcess to it :)
Dec 25, 2007 | Toshiba (SD-R2412) for Satellite A10, A15,...
Samsung SN-S082D DVD RW Dual Layer Burner Logo
120 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
