Question about Gateway Computers & Internet
Received a replacement keyboard from gateway but, no installation instruction included.
  • 124 Answers
You put this in the PC Desktop category. If it's a desktop, then you just plug it in. If it's a laptop, then you'll need to turn the laptop over and remove the screws that correspond to the keyboard. Look for ones that are in relatively the same place as the four corners of the keyboard and such. Once removed, flip the laptop over and gently pull/unsnap the keyboard. Do this carefully as you will need to see where the keyboard plugs into the motherboard. Next, simply plug the new keyboard in and reverse the steps. It's really an easy process once you start doing it. Good luck!!
Posted on Sep 26, 2008
  • 36 Answers
The keyboard should have a USB plug or a PS/2 plug that should plug right into the back of your computer
How do I replace a keyboard on a Gateway NE522?
Laptop keyboard replacement procedures are all similar,
Search on the internet for how to replace ne552 keyboard (or similar). You my find quite a number of nearly relevant instructional videos and step-by-step instructions, referring to slightly different models..Look at a few and see how similar they are, pick one and follow it eg
Replace Keyboard Gateway Laptop or
Replace Keyboard on Gateway Laptop NE56R
What you really need is the maintenance & service manual, but there doesn't seem to be one. You might try contacting Gateway support and asking.
Keyboards for your model are readily available, on ebay or from commercial parts suppliers, even Gateway
Nov 05, 2015 | Gateway Computers & Internet
Gateway wireless keyboard detection
Insert the installation CD that came with your wireless keyboard set into your computer's CD-ROM drive.
Use the CD to install the drivers for the wireless peripherals.
Insert batteries into the keyboard .
Use a screwdriver to remove any screws that hold the battery bay covers closed.
Connect the wireless signal receiver to your computer.
Receivers for wireless keyboard and mouse sets usually use a USB connector.
Your computer will automatically detect the receiver.
Turn on your keyboard if the devices have power buttons.
Press the "Sync," "Connect" or "Pair" buttons on the keyboard , depending on your model.
If present, press the "Connect" button on the wireless signal receiver as well.
Your wireless keyboard set is now connected.
hope this helps
Oct 13, 2012 | Gateway One Computers & Internet
How to replace gateway 3040 keyboard, need to know method to open the laptop to install a replacement keyboard
Visit this site and follow the instructions carefully.
Please rate me thank you
Apr 10, 2010 | Gateway 3040GZ PC Notebook
Replacing Power Button Circuit Card on Gateway W730 K8X Laptop
The instructions for replacing the keyboard include the cover you have to remove to replace the power button pcb. The power button pcb is attached to the bottom of the bezel that covers the hinges/button array. In a nutshell you just remove the 2 screws indicated in the instructions, pry the hinge covers up a bit, then gently pry the bezel up from the bottom. remove the ribbon cable, pull back the small piece of tape, remove the three small screws holding the pcb on, and remove it from the spring clips.
Apr 11, 2009 | Gateway Computers & Internet
GAteway wireless keyboard
is your battery brand new? install a new one, if the problem exist, try to unplug and plug again the usb keyboard receiver, if the problem goes again, you need to contact your keyboard's manufacturer since it is a newly bought, it is still under a warranty. so you must contact them, to have your keyboard replace by a working one
Good luck, Godbless
Jan 21, 2009 | Gateway 2520915 Keyboard
Wireless keyboard
It could be a bad battery in the keyboard itself (I would suspect this first) or You may need to download and install the 'driver' from Gateway.
Sep 30, 2008 | Gateway 2520915 Keyboard
Missing Keys on the the keyboard, want to replace the whole keyboard.
If you are handy with a screw driver and take your time, you should have no problems replacing your keyboard.
Tools Required: A small Phillips and a small flat-blade screwdriver are required replace the keyboard.
Gateway has excellent documentation on how to replace your damaged keyboard.
The User Guide you require is 8511418 - Component Replacement Manual
Detailed instructions can be found on pages 7 and 8 of the User Guide. If you have any qeustions please ask.
Good Luck!
Aug 11, 2008 | Gateway MX6447 Notebook
How do I replace the damaged keyboard on my Gateway MA3 MX6447 to install a new keyboard? The damaged keyboard has missing keys. Thank you!
Checked the Manual....
Instructions to remove and replace the Keyboard can be found from page number 7 in the Manual.
Link to get the Manual :
can contact Gateway Chat Support through link below:
Hope this helps
Aug 11, 2008 | Computers & Internet
I received the replacement keyboard for my Gateway laptop computer without the "easy to read instructions". I was hoping that these instructions for removal of the defective keyboard and...
The best I could find was the product page for the keyboard. Otherwise you'll need to either contact the people who you bought it off or use a general guide for replacing keyboard such as this one. It does have laptop - specific instructions for some Gateway laptops - hopefully you'll hit lucky!
You could try searching specifically for "(your laptop make & model number) keyboard replacement guide" if the above link does not work. Google usually has the answers! Alternatively if you provide me with the model number I could have a look around for you.
Hope this helps and good luck!
Jul 13, 2008 | Gateway Computers & Internet
Warning: receiver channel changed - wireless keyboard and mouse
I contacted Gaeway Support. They quickly answered and suggested that I change the batteries in my wireless mouse and/or keyboard. I did. It was the mouse. As soon as the new batteries were in, the popup went away and stayed away.
Jan 07, 2007 | Gateway 2520915 Keyboard
Computers & Internet Logo
61 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
