Question about Mr. Coffee FTX49 12-Cup Coffee Maker
Leaks while filling
I have Mr. coffee FTX49 and on several occassions while filling,water leaks out all over counter and floors instead of filling. What would cause this? Thank you,
Mine just leaked and it turned out to be one of the rubber tubes from the reservoir to the heating element under the pot came off. I removed the 4+2 screws of the base plate, reinstalled the tube & since there are no clamps holding on the tubing, I used thin stainless wire double wrapped and snugged to ensure the tubing stays on this time. Note, there is wiring in the area. Make sure you do not short out any of the electronics with the wire if you chose to use it.
Posted on Apr 03, 2010
There is a lever in the back of the carafe area that pivots and controls a spring loaged valve on the bottom of the removeable filter basket. This lever breaks easily. Pull the filter basket out and you can see the lever hanging down into the carafe "bay". (assuming it's not broken off entirely).
If you pull the pot out during brewing, the lever swings forward and allows the valve on the bottom of the filter basket to close. This shuts off the flow of coffee to avoid drips. The plastic lever is held in place underneath the valve by two round tab "ears". One of these ears can break off, causing the lever to hang at an angle. This means the filter valve never completely opens, even if the pot is pushed in all the way. During brewing, the filter basket can't drain into the pot fast enough and overflows.
I fixed mine by going ahead and removing the damaged lever and then wedging the valve open. The spring loaded valve has a little drip "Spout" which hangs underneath the filter basket that directs the coffee into the pot. You can push in on the back of the drip spout and wedge something into the two slots at the back to hold the valve open. This let the coffee flow freely during brewing.
Posted on Nov 26, 2009
Hi. That is very easily fixed. Do not over fill the water resovoir. In this case MAX. 12 Cups means MAX. 12 Cups. If you take a look at the backside of the coffee maker you'll notice, just above the hole where you can store the cord, there is a smaller oval hole with a rubber "thingy" inserted. this is to prevent you from overfilling the water resovoir causing the water to run into the more damaging parts of the maker. It is somewhat annoying but a safety feature to protect you from harm.
Next time you fill the machine take a look on the back to verify that this is the reason for the water on the counter top.
Posted on Dec 05, 2008
  • 58 Answers
I just took a look at my mr coffee and noted the water resivoir is removeable. I wuld make sure the resivoir is fitted properly and snugly to the base.
Posted on Sep 26, 2008
Why does my mr. Coffee decanter leak?
First I'm not a Mr. Coffee tech but I have worked on similar machines.
* Most decanters are made of tempered glass and unless cracked it should not leak.
* Most overflowing pots are caused by over filling brewing tank. This can be caused by re-pouring additional water into the brew tank. (automatic brewers may have a leaking water valve - call your vendor for service)
* Partial brewing (taking coffee from a brewing pot) and then putting in more water.
* Removing the pot BEFORE it stops dripping. It leaves a puddle of coffee on the warmer plate
*Over filling the water tank. Most times the extra water will spill out the back. But some may overflow into the basket area then the warmer plate.
* Follow the MFR brewing instructions for filling.
* All brewers should stop water drips after brewing. If you get a constant drip AFTER brewing then have the brewer checked or replaced. Call your vendor.
Aloha, ukeboy57
Jan 15, 2018 | Mr. Coffee Coffee Makers & Espresso...
Why does my Mr. Coffee pot fill and overflow with more coffee than the 12 cups of water that was put I the reservoir?
Looks Mr Coffee has a matter generating hability., defying basic laws of the universe. Kind of a "Little Bang Theory". Seriously, no, it has no secret water compartment. Possibly some water remaining there from previous use.
Jun 24, 2015 | Mr. Coffee Coffee Makers & Espresso...
I am not able to get any coffee through the coffee dispenser. It just fills the overfill tray and leaks from under the machine onto the counter. Any idea what the cause is and how it can be resolved?
Try running a mixture of 1/4 cup Apple cider vinegar in a pot of water then flush with pots of cold water until no more vinegar odor. This immediately breaks through hard water scale buildup. You may also have a bad seal if it is leaking. You can get a repair kit from Mr. Coffee or if you have a Bunn, they have lifetime guarantee. You can return for repair, or request repair kit by contacting them
Jan 23, 2015 | Coffee Makers & Espresso Machines
Looking for instruction manual for mr coffee model ftx 49
Here is an instruction manual for the 12 cup progamable coffee maker the ftx series, the numbers are for the color so this manual should work just fine here is the link:
Thank you for choosing
Apr 02, 2011 | Mr. Coffee FTX49 12-Cup Coffee Maker
How do I take apart, and clean my coffee maker?
The only parts that should be removed to clean are the pot and the basket. The remaining parts you just clean with a cloth and hot soapy water (squeezed out) then you clean the inside with 1 part white vinegar and 1 part water. Run a cycle through the pot then run again with just plain water. This do once every 3-4 mos. depending on how often you use your coffee pot. You can actually put them on the top of a dishwasher rack also. You may risk electrical shock if you take it apart.
Oct 09, 2010 | Mr. Coffee FTX49 12-Cup Coffee Maker
MR COFFEE FTX49. Brewing starts, then stops
Mine just started to do the exact same thing. So I decided to clean it using the "Clean" program and just water. I put the brewer through the cleaning program 3 times - each time it would brew water from 12 cups to 8 cups, I'd tap the brewer on the countertop, it would brew from 8 cups to 4 cups, tap it again, and it would brew the remaining cups. So, I called the Mr. Coffee help line (800-672-6333). The most-likely problem is that the hose is no longer attached in the water reservoir. The help line suggested that I take it in to a service center. I live in Urbana, IL and the closest service center is in Oak Lawn, IL - 2 hours away from me!!
Here is my solution:
1) Buy another coffee brewer.
2) Smash your current Mr. Coffee brewer into a million pieces (this relieves stress) and go buy another coffee brewer (probably stay away from Mr. Coffee products).
Hope this helps.
Frustrated in Urbana
Oct 11, 2009 | Mr. Coffee 12-Cup Programmable Coffeemaker
Maker clicks on, but doesn't perk or heat the plate.
Unlike older coffee makers, the new Mr. Coffee designs seem to have reliability issues in regard to their circuit boards/controllers. You are right in your thoughts. If the unit is under warranty, I would suggest returning it for a replacement. E-mail your concerns directly to the company.
BTW--there are no user serviceable items within your coffee maker.
Mar 26, 2009 | Mr. Coffee FTX49 12-Cup Coffee Maker
Mr. Coffee FTX49 12-Cup Coffee Maker Logo
624 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Kelley Hopper
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
