Question about Symbol LS2208 Handheld
Can not scan Code 128 bar code
My Symbol LS2208 scans 3 of 9 fine. Is there some setup that you have to do in order to scan both 3 of 9 and code 128?
  • Anonymous Mar 20, 2009
    mi symbol ls2208 is not reading 128 bar codes
  • mariah
    mariah May 21, 2014
    er..just know this code 39 barcode scanner and the code 128 barcode scannerhttp://www.keepautomation.com/products/n...
  • 661 Answers
You should have a code book with the scanner setup barcodes in it, you need to enable code 128 by scanning the appropriate codes in the code book.
Posted on Sep 30, 2008
I can't set to read a barcode 128 with symbol ls2208. I have scanned the "enabled barcadeo 128" on the manual but nothing happends... please help
Sometimes it can be something as simple as scanning another code and retrying. Don't forget to scan the save command.
Jul 06, 2011 | Symbol LS2208 Handheld
How do I get my Symbol LS2208 to recognize EAN128. I need it to prefix [C1 when a EAN 128 is scanned.
you need to scan some of the bar codes found on the manual.
Find the product reference manual -usually found on the cd with the scanner or download from motorola site - and in chapter "symbologies" scan "ENABLE CODE128" barcode.
To have prefix when a code is scanned, scan "SCAN OPTIONS" then " then "ENTER"
Last set the preffix value by scanning "SCAN PREFFIX" then four digits that correspond to the character you want to use as preffix.
If you need more than one character for preffix then you will need the Advanced formatting manual, which ican be downloaded from motorola. In this case you need to create a "rule".
Let me know if you need further assistance
Nov 11, 2010 | Symbol LS2208
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
What is the bar code for the tab key
Hi paulajoy. I believe I can help, but I'm not sure what you mean. What are you trying to do? Configure your scanner to put a {TAB} keystroke in when scanning? Or are you just looking for the code for a {TAB} keystroke? If you are just looking for a code to identify it, the ones I know of are: ^I for Character, 09 for dec, and 09 for hex. If you're trying to configure your scanner, let me know and I'll be happy to help you find the right barcodes in the manual.
Jan 01, 2010 | Symbol LS2208 Handheld
I would like to transmit EAN-13 bar code without check digit, but closed by ENTER.
If you would like the LS2208 to transmit only the first twelve digits of an EAN-13 barcode followed by an enter you will have to write an Advanced Data Formatting rule using barcodes from the LS2208 Product Reference Guide found here: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=114420371&stateId=1%200%20114410810
The barcodes you will print and scan in the order they are listed are:
Begin New Rule
EAN-13 (from the Critera pages of the ADF section)
Send Next 12 Characters
Send Enter key
Save Rule
If all other barcodes require an enter key make sure you scan Scan Options, Data Suffix, Enter (from the same manual or from the Quick Start Guide) before scanning the ADF rule above.
Jul 13, 2009 | Symbol LS2208 Handheld
When i scan a barcode why do i have to push enter?
Go to http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201bpdf&sliceId=&dialogID=111756507&stateId=0%200%2011492385
This is the quick start guide for the LS2208. On the first page you will see a section titled Carriage Return/Line Feed. Scan these three bar codes from top to bottom. That's it.
Jun 25, 2009 | Symbol LS2208 Handheld
Program Symbol LS2208 scanner
Hello this requires advanced data formatting which you will have to scan some bar codes to program it. If you give me your email I can send the codes to you.
Jun 19, 2009 | Symbol LS2208-7AZK0100S Handheld
Symbol handheld scanner problems
scanners are just plug and play.. be sure the scanner is programmed to read the type of bar code you are scanning.. Check the symbol to make sure it is not defaced. Try scanning test symbols of the same barcode type. and last tip, move the scanner closer to or further from the bar code.
Aug 11, 2008 | Symbol LS2208 Handheld
Symbol LS2208 Handheld Logo
2,863 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
