Question about GE JGBS07PEAWW Gas Kitchen Range
GE Gas Range JGBS07 PEHWW
Oven turns on by itself several times daily. Oven turns on by itself several times a day. Please help. No gas smell.
  • tonyromo Sep 26, 2008
    MY GE JGBS07 Gas oven is turning on and off by itself repeatedly. Is there a danger of a gas leak?
    Brigadier General:
  • 6,966 Answers
I am assuming that by your post "...urning on and off by itself repeatedly...", you are referring to hearing the clicking sound normal when the igniter is toggled/activated. Since you posted that there is no gas smell, then presumably you are safe. Of course, XX suggestion should be taken into account.
Initially, I would suspect that there is moisture/dampness in the igniter switches. this could be brought about by a recent cleaning, rainy weather or anything involving water/liquid. What happens is the switch engages by themselves (not the gas valve) and triggers the igniters producing the spark/arc.
This could be resolved by cleaning/drying or worst case replacement of the switch(es).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 26, 2008
  • Louie  Role
    Louie Role Sep 26, 2008
    Ooopps, sorry, that should read as "Of course, ginko suggestion's..."
  • GE Master
  • 19,396 Answers
When this happens, it means the valve is faulty, there is risk of gas leak, CO poisoning, and fire hazard.
Gas appliance need always special attention.
Whenever a gas appliance is behaving erratically, call immediately service number listed on the owner manual.
Regards
    Genius:
  • 1,550 Answers
It seems to be power supply issue in your oven .
The main board is not having proper power supply .
Did you check this ?
SAM ANDERSON
Gas fumes from maytag range
"The professional gas installer has been here several times to check the. Gas lines." Ask the professional gas installer to do a leakage test and inspect for a cracked gas line.
Jul 29, 2017 | Maytag 30" Self-Cleaning Slide-In Gas...
20" gas stove: has pilot light in oven, oven lights but then after several minutes will turn off. do not smell gas after it turns itself off. Using 3/8" gas line. Please advise as to potential problems...
The oven igniter should stay on constantly as long as oven control is calling for heat and not fade off. If the igniter is too weak and not pulling enough current it may not open the gas valve correctly and gas will be let out of the gas valve and not igniter.
The likely failure is a weak oven glow bar igniter. I recommend calling a service technician to diagnose and repair your range.
Hope this helps .
Apr 21, 2010 | Microwave Ovens
Gas smell when oven is on and heating.
This sounds like a gas leak at the gas control valve for the oven, probably somewhere just past the control valve. If the leak was before the valve, you would either hear or smell gas leaking all the time.
The line could simply be loose at the fitting or the gas valve could be faulty. You could also have a leak somewhere at or before the oven burner assembly.
At any rate, this condition can be dangerous. The oven gas leak (any gas leak) should be diagnosed by a competent technician and the cause(s) of the gas leak determined as soon as possible and corrected.
Jan 13, 2010 | GE Profile JGSP48 Gas Kitchen Range
GE oven ignitor replaced, gas turns on but no flame
Yeah, blowing up the house is never a good way to replace an appliance :)
Try contacting GE at: http://www.geappliances.com/service_and_support/contact/form_service.htm. It should be free and they'll be able to help you narrow down what's going on.
Alternately, new GE ranges start at a little over $400 at Home Depot... You certainly have to appreciate keeping a good appliance going, but if it starts nickel & dimeing you, it may be that range's time to go.
May 24, 2009 | General Electric Stove/Oven/Range Chrome...
GE Profile Gas Range oven light doesn't work even after changing
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge gas oven with electronic ignition
yea sounds like you have a bad oven ignitor, tell tale signs are not heating past warm, smells gas, too long to cook, popping noises while cooking. Id replace that ignitor. Although it might appear to "glow" not glowing strong enough
Feb 28, 2008 | Kitchen Ranges
Oven not working after controller beeping
if ihe oven is not working. ck ihe igeniter in side ihe oven it trun red hot when you trun the oven on
Dec 31, 2007 | GE JGBP33 Gas Kitchen Range
GE JGBS07PEAWW Gas Kitchen Range Logo
122 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
