Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
WD My Book 1TB, not recognised by XP
Hi Benimur. My WD 1TB My book worked perfectly until I plugged a USB2 hub into my computer. ever since the computer has failed to recognise the "My Book". I have reinstalled all my drivers, powered the unit off & on and I am using wall power. Do you have any suggestions??
  • precipice Sep 26, 2008
    Thanks Benimur. I tried your suggestions. My digital camera works fine in the USB port. I don't have quick access to another PC so haven't tried the HD on different system yet. I checked the registry. My settings are identical to yours including the (3). What I did do then was to plug the USB hub back into my PC and try running the HD through the hub. I now have my HD back !! (stranger things have happened)......Thanks for your advice & trouble shooting tips.
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
A couple of ideas:
  • initially, confirm that it is the PC's USB ports that is the issue by trying the WD on another PC;
  • try plugging in a flashdrive, camera to your PC's USB port;
  • if it has been verified that the WD works in other PCs and that the USB port of your computer works, then it could be a registry entry.
Please open "regedit":
  • go to HKLM\system\currentcontrolset\services\USBstor;
  • check the value of the DWORD "Start" it should be 3;
  • If the DWORD "Start" does not exist, pls create it. Right click, New, DWORD value, Start, Value Data = 3.
Incidentally, there is Microsoft KB about disabled/disabling USB here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 26, 2008
  • Louie  Role
    Louie Role Sep 26, 2008
    Here is an image of how my XP's HKLM\system\currentcontrolset\services\USBstor
  • Louie  Role
    Louie Role Sep 27, 2008
    Appreciate the postback/comment and am glad that the WD is readable again.
I have a brand new WD 1TB My Book delivered today not recognised
Pleaes open the Device Manager and right click on the Yellow exclamation mark.
Now, click on update Driver and select Install from Advanced Location.
Type the Location as C:\Windows\inf and click on Ok.
The Driver should be installed now.
Jul 13, 2010 | Western Digital My Book Essential 1TB...
I have a WD 1tb My Book and it stopped being recognized
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Feb 28, 2010 | Western Digital MY BOOK HOME 1TB EXT...
How to format WD Passport 1TB to FAT32 I have used WD external 500GB passport drive with my samsung 1080p9 dvd player successfully WD 1TB passport drive is not recognised by dvd player
Plug the drive into your PC.
Right Click on My Computer (or Computer in Vista/Windows 7) and select Manage.
Click on Disk Management.
Right Click the Volume in question and select Format. Select FAT32 in the options.
Dec 24, 2009 | Western Digital My Book Essential Edition...
No power to my WD 1TB
If its under warranty then get it sent back.
If its not then almost any 3.5 " external sata enclosure will do so long as it has its own power supply. and if that supply is a wall-wart then should you pooch that, they are so easy to pick up and replace.
If you need quick access to the files remove the disk and fit it to a suitable computer.
If this information was useful please click
Aug 14, 2009 | Western Digital MY BOOK HOME 1TB EXT...
Western Digital 1T MyBook keeps crashing
it seems a problem with the driver, try plugging it onto a different computer. If that works, reinstall the driver.
Computer freezes on start-up when western digital 1tb external hdd plugged in to computer, computer starts fine with it unplugged. The hard drive can be plugged back in after start-up.
This is a known problem with these drives. Disabling USB legacy support in your Bios should solve the problem., it did in my case but at the expense of not being able to boot from a USB device. Definitley a problem with their enclosure or drive.
Ken D
Aug 11, 2009 | Western Digital MY BOOK HOME 1TB EXT...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
WD My Book 1TB not recognised by belkin modem router USB storage
I have a work around for this.
In the detail of the Belkin manuals it says you can attach up to 4 USB storage devices via a USB HUB.
I had an old Hub so I Connected the HUB to the router and the Maxtor to the HUB --- It worked :-) It came up in a few seconds.
At first I powered the HUB but later took the power out of the hub and it still worked ;-} However when I used a different HUB it would not work without power to the HUB.
The HUB I use is an old Belkin 4 port Tetra Hub. The newer 7 port Belkin HUB (5 Rear 2 Top) only worked with the HUB powered.
Hope this helps untill Belkin Upgrade the Router sofrtare.
Apr 07, 2009 | Computers & Internet
I had this same problem, it worked then just stopped. So i bought a new USB card and that worked fine. But know all the old USB ports works aswel. Weird...
Sep 26, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
322 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
