How do I transfer documents from my main hard drive to the new hard drive
    President:
  • 1,257 Answers
Use windows easy transfer or you can connect the hard disk to the system and manually copy and paste the data...........
Posted on Sep 26, 2008
2 Suggested Answers
xerick
  • 139 Answers
SOURCE: Install 2nd Hard Drive in a Dell Dimension 8400 Computer
all u do is make your new hard drive the master by setting the correct jumper for it the manual will tell u more. then make the old drive a slave. install yr opreating system it should be installed in drive c: thats the master when done, u do yr normal copy and paste to transfer your files from old drive to new drive.
xerick
Posted on May 23, 2008
Does not allow transfer of files or pictures
Plug the external hard drive into your laptop or desktop computer.
Most external hard drives do this through a cable connecting the hard drive to the USB outlet on a computer.
Plug your external hard drive into a wall outlet if it receives power from an AC adapter rather than your computer.
Click on the "My Computer" icon on your desktop, and open the external hard drive.
It will be located under the USB connecting drive, which is labeled with a letter ranging from "E:" to "K:".
Open the folder on your external hard drive where you would like to save the photographs.
usually in my documents my pictures or if you want to save them to a specific spot so as not get them mixed up.
Create a folder if one is not present right click in my documents select new folder and name it lets say my pics 1
Move this window to the bottom right corner of your screen to be used in future steps.
Open the folder on your home computer where the files are being stored that you wish to transfer to the external hard drive.
These may be on the desktop, in "My Documents" or elsewhere in your computer.
If you are unsure where they are located, you can always search for them by file name by going to "Start" then "Search."
Right-click on the photo file, and select "Cut."
Click on the window showing your hard drive files to bring it into use on the screen.
Right-click on the white space in the window where you would like to transfer the files, and select "Paste."
Your files have now been deleted from their original location and transferred to your external hard drive in the folder you selected
hope this helps
Sep 27, 2012 | SimpleTech Signature Mini 160GB External...
Do i have to transfer all my hard drive data when installing a new desktop pc
No you don't need too, but you might want to copy all your documents, music and pictures to your new computer.
Jun 12, 2012 | Fujitsu Computers & Internet
Help transferring files from computer hard drive to La Cie
Well you can ONLY transfer/Move DATA as Programs and Documents & Settings and User Directories, cannot be shifted at all. So It is only the Files and Data that can be Moved off a drive. To gain space back, Right Click on the HDD, go to properties, in properties Under the general, tab the first window, select disk cleanup, remove everything in those boxes and after, that look under Tools tab, & do a disk defragment. This may get you space back. If not you may have to get a new bigger drive, and clone your old drive, then install the new drive and reinstall the Cloned image back onto the new drive?
Mar 30, 2010 | Computers & Internet
How do you transfer the info on my hard drive to an external hard drive?
The easiest way is to use Windows Explorer to do it. (NOTE:This is not Internet Explorer.)
Go to Start>All Programs>Accessories>Windows Explorer
When the window opens, you will notice 2 panes: left and right.
Click on the little + next to My Computer. You should see your external drive listed. (It will probably be an E: or F: drive if you don't have other drives attached.)
You can click on the + next to that drive too. If you have nothing on it, the + will just disappear.
I am assuming you want to transfer pictures or documents for backup.
You can "Drop and Drag" any files and folders to the new drive by doing just that. Say you want to transfer all your pictures. When you have clicked on the + sign and expanded the list on the left, now click on My Documents on the left pane. Everything in My Documents will now be listed on the right pane. Click and hold the left mouse button on the My Pictures folder on the right pane. Do not let the button go. Now drag it over to the left side over the new drive. It will become hi-lited. Now let go of the mouse button. Everything in your My Pictures folder will be copied to the new drive.
Repeat this procedure for all other files or complete folders you want to transfer.
Thanks for using Fixya.
If you have any problems, just Comment back.
Jan 25, 2010 | Microsoft Toys
I have an old sony vaio with a 60 gb hard
How "full" is the hard-drive? Perhaps, you could have only a few gigabytes to be "saved".
Click Start
Click My Documents
Click Edit
Click Select All
Right-mouse click on any of the highlighted items.
Click Properties.
Windows will report on the size (megabytes/gigabytes) of all the selected documents and folders.
Perhaps, you can buy 4GB or 8GB or 16GB USB memory-stick,
and manually copy your 'My Documents' files/folders to that memory-stick.
Or, use the "Windows Files and Settings Transfer Wizard" to "collect" all your files & E-mail, and write an "export" file to that memory-stick.
Then, on the "new" computer, run the same Wizard, and "import" from the USB memory-stick onto your new computer.
Dec 31, 2009 | Mirus (SITL51C410) Notebook
Need to transfer copied files to x301 after full restore
create a new folder in your hard-disk and first try to copy 1-2 files from the external hard-drive to the new folder (copy any data/work/images you have stored/created not any files of windows folder or root of c: drive)
if the above copy works then copy back all except the c: root and these folders - Windows folder, Document & settings, Program Files
May 30, 2009 | Lenovo ThinkPad X301 2776 Notebook
Document transfer from vista hard drive to memory stick
4gb is not enough space to hold the entire My Documents directory unless you have an extremely small amount of data in it. If you take many photo's it wont be long before My Documents is too big to fit. Suggest that you back up this directory to a set of CDs or DVDs,
If you want to update a memory stick just copy My Documents from Vista to the memory stick. Vista will ask if you want to overwrite. Click [on overwrite all] and the job is done.
Jan 10, 2009 | SanDisk Open Box 1GB Cruzer Mini...
Transfer memory from hard drive
Hey jockos,
If you're positive that it's only the motherboard on your first computer that's currently defective, you should have a number of options available to retrieve files from your hard drive.
Generally, the easiest way to do so is simply installing the hard drive into another computer. This should allow you to transfer files back and forth between the two installed drives freely, using a standard drag-and-drop method. Often step-by-step instructions on how to install a second hard drive can be found in your computer's owner's manual documentation, but may just as easily be found by looking for "how to install a second hard drive" using an online search engine.
Please keep in mind that once the hard drive has been installed onto another computer, it is strongly suggested that you only copy and transfer saved files such as word documents, spreadsheets, pictures and movies to the new drive. Transferring full programs and executable files manually may result in software conflicts/errors which may not be easily resolved.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 02, 2008 | Computers & Internet
xerick
May 22, 2008 | Dell Dimension 8400 PC Desktop
"The device is not ready"
This error message means that the preferences in EasyShare software are set to save pictures to the CD-ROM drive or some drive other than your hard drive. To correct this, follow these steps: Start EasyShare software. Select Tools > Preferences. Select the Transfer tab. Below "Select the location on your hard disk where you want to copy transferred pictures," select Browse. Browse to the desired location on the hard drive where you want to transfer your pictures. The default location is: For Windows 98/Me Operating Systems: c:/My Documents/My Pictures/Kodak Pictures For Windows 2000/XP Operating Systems: c:/Documents and Settings/user name/My Documents/My Pictures/Kodak Pictures Select OK to return to Preferences, then click Apply and OK to save and close the Preferences. Reconnect the camera, and transfer the pictures.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
