Question about Rowenta Power Duo Iron
Iron leaks water from the back end of the base
My Rowenta Power Duo leaks water from the back end of the base on one corner. It has been a problem almost from the beginning of use.
I also bought a less expensive Rowenta for my daughter and it also leaks.
I am very disappointed with the product.
  • 3 more comments
  • didiquesada Oct 03, 2008
    Water leaks out of the corner in the back. I've had two of these and they both have the same problem.
  • mgrhine Oct 29, 2008
    Mine also leaks after only 4 months use. Marje
  • Anonymous Nov 26, 2008
    My power duo is 5 months old and it also leaks from the bottom corner.
  • fareall Mar 17, 2009
    Any disassembly diagrams someone can share?
  • ironmaiden Jul 20, 2013
    empty the reservoir after each use and turn on before filling. works for me
    New Friend:
  • 18 Answers
This problem is the way that rowenta seals the water tank. If the iron is disassembled and the seal is properly put on it will not leak,, however this seal is a silicone based product and not just an off the shelf gasket. I have sealed and repaired some using a high temp silicone
Posted on Mar 06, 2009
Water in iron and sometimes water runs out on board. also wont steam
I GUESS THE SPRING WHICH ALLOWS THE WATER TO FLOE MIGHT HAVE GOT LOOSEN.
Mar 07, 2012 | Rowenta Power Duo Iron
Rowenta Iron leaking out of bottom and leaks on clothes
I have one of these and have been battling the leak problem for years. I'm a stubborn mechanical engineer and I'm bound and determined to fix this, when in fact I should just buy another, different, iron.
The problem is then 'handle'. Built into the handle is the water tank. The water tank is made from two pieces which are then glued and screwed together. Think of taking a coke bottle, cutting it in half, and then gluing it back together. Now you see where the problem comes in... the glue they use isn't up to the task, or the heat... or the pressure... is causing the tank to leak somewhere / everywhere.
I have disassembled this several times, meticulously scraped out the old silicone, and tried several different types of silicone to re-seal. So far it always fails. It's good for a while, but maybe a couple months, before it starts leaking again.
Conclusion... BAD DESIGN. Very disappointing, because in every other respect I like this iron better than any I've ever owned.
Jul 14, 2010 | Rowenta Power Duo Iron
When the iron is set for steam it spits volumes of water
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Apr 11, 2010 | Rowenta Power Duo Iron
I have a rowenta iron, and began to iron a tablecloth with gold embossing. Now it is stuck on the plate. How do I clean it?
Turn the iron back on, get a sheet of wax paper, iron back and forth on the wax paper it cleans all of the gold and grime off. Then take a Magic Eraser and clean the plate after it has cooled. Won't scratch your plate. Hope this works for you. I have done it often.
Dec 31, 2009 | Rowenta Power Duo Iron
I have a rowenta iron that leaks a lot of water
Here's a solution . . . Do NOT buy ROWENTA! I've had 3 Rowenta irons. All of them have eventually began to dump water out of the base. . . heck, the Titanic didn't leak as much as a Rowenta iron!
Dec 31, 2009 | Rowenta Perfect Iron
My Rowenta iron is leaking down by the cord. can
Try using different water...
heatman101
Oct 16, 2009 | Rowenta Professional DE880 Iron
DG050 Rowenta how do you clean out the base(where
If you live in a hard water area add a bottle of kettle descaler and some hot water , leave for 1 hour then rinse out thoroughly
Aug 21, 2009 | Rowenta Steam Generator DG050 Iron
I have a rowenta iron. When I am ironing the
heatman101
Jun 25, 2009 | Rowenta DX6700 Iron
Removing deposits on iron plate
Try adding some CLR to the iron, fill it up with water, and run self clean. Then wipe bottom of iron with an old towel. Repeat with clean water in the iron, to rinse out the CLR and minerals.
Jun 21, 2009 | Rowenta Power Duo Iron
I have a Rowenta Power Duo iron that just quit heating. Is there a place in Memphis, TN that can repair it?
This is the main information about your iron.
You can call them and they will help you to find the right place
Rowenta Inc.
196 Boston Avenue
Medford, MA 02155
Tel: (781) 396-0600
Monday-Friday
from 8am to 5:30pm (EST
Good Luck
Jun 17, 2008 | Rowenta Power Duo Iron
Rowenta Power Duo Iron Logo
2,069 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
