Question about Kenmore 24032\24036 Top Load Washer
Kenmore model #110.26442502
Last night I filled the washer with a comforter and pillow cases! It was working fine and then I lifted the lid. Now it wont start back. Any ideas. It is full of water and had already started agitating
  • dagreens Sep 27, 2008
    Of Course it is not that simple! Thanks anyway
  • 750 Answers
Hello dagreen,
Welcome to fixya.
I'm Huuum and happy to assist you,
You said,
Last night you filled the washer with a comforter and pillow cases! It was working fine and then you lifted the lid. Now it wont start back. Any ideas. It is full of water and had already started agitating.
Check the breaker
Could the power be out due to an electrical storm while you were sleeping.
If not!
Try pulling the plug out for 5 minutes or turning the breaker off if you can't reach the plug.
Then try to start. this should have reset the system.
Some Questions to check
• Is the drain hose clogged, or the end of the drain hose
more than 96 in. (244 cm) above the floor? See the
Installation Instructions for proper installation of drain hose.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
• Is there excessive sudsing? Always measure detergent.
Follow manufactures directions. If you have very soft water,
you might need to use less detergent.
let me know how you do and that it works.
Huuum
please remember to leave a rating when your finished.
Posted on Sep 26, 2008
I have a Kenmore 700 series washer and it fills with water then stops. It's NOT my lid switch. I have tried to find someone with the same washer and same problem and can't find nothing. Can someone please...
If you are sure its not the lid switch, then next would be the water level switch. Once the machine fills, it should switch an internal set of contacts to make the washer run. Last and worst case scenario would be a dead motor.
Mar 24, 2015 | Kenmore Washing Machines
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
My washing machine model 110.24642300 was washing last night and just stopped after filling half way. what do I need to do
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Good luck...
Mar 28, 2009 | Kenmore Washing Machines
Washer fills with water and just sets there spin cycle works
The timer is failed in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer 60 series
Hi, thanks for using the FixYa service. Your lid switch is probably broken. Make sure you can hear it click when you open and close the lid. It it is a very common problem on that model. Probably has nothing to do with the pillows, that was just the last load in the machine before the common part failure. Get me the exact model number and I can get you the replacement part number.
Dec 19, 2008 | Kenmore 24032\24036 Top Load Washer
Washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Nov 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer just stopped
This is a typical symptom of a defective or loose lid switch. If you open and close the washer lid, you should hear a clicking noise as the lid switch activates. The lid switch is usually located on the right-hand side under the washer casing rim. It is activated through a small slot, by a plastic piece on the lid called a lid strike. There are two mounting screws adjacent to the slot that hold the lid switch in place. Sometimes the screws come loose, or the lid strike breaks off, causing the switch not to activate. Or..the switch simply fails over periodic use. This results in the symptoms you describe. The washer fills, but fails to spin or drain. This is a simple repair that you can accomplish yourself. For step-by-step instructions, please refer to the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you require assistance in locating replacment parts and/or have further questions, please post back with your complete model number (located aorund the tub rim), along with your comments. That way I can assure the accuracy of any part numbers.
NOTE: Use care not to slam the washer lid. This can also cause premature failure of the lid switch components.
Jun 16, 2008 | Washing Machines
KENMORE 80 SERIES
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, replace lid switch. If this washer has a hidden lid switch, check the lid hinge screws and make sure they are screwed in tight.
Jun 01, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
273 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
