Question about HP DeskJet 5550 InkJet Printer
Multiple copies When I select for several copies of something it always prints more than I requested. Example: 40sets of 3 pages. It will say 1 of 40 on printer and print 40sets, then go to 2 of 40 and print 40 more and so on.
  • sonservicece Sep 26, 2008
    Thanks, but the collate box is checked when this happens.
    President:
  • 1,901 Answers
Look for a small "Collate" box and make sure it is checked. That way it will print each set in order.
Posted on Sep 26, 2008
How do I reduce a page being copied?
scan a copy to pc documents , save to word , use photo shop and reduce in size
print page and then re-scan
Sep 17, 2017 | Office Equipment & Supplies
My printer prints multiple pages even though number of copies in setting shows 1
Try looking here: open your printers fax folder. Your printer should be listed here, right click on it and select properties. Now click on the advance tab. There should be a printer defaults button, click on it. Make sure your copies number is set to 1. Then click ok on each window and close.
Hope this helps
Feb 13, 2012 | Dell 1320c Laser Printer
Epson 600 stuck on making 3 copies,no matter if i set it for one copy
Select Basic Print Options After opening your file for printing, open the Print window to select your print options. 1. Open the File menu and select Print. 2. Click the arrow to expand the Print window, if necessary. wf600.1.86.1.jpg 3. Select EPSON WorkForce 600 as the Printer setting. wf600.1.86.2.jpg 4. Select the copies and pages settings for your print job. Note:
If you don't see these settings here, check for them in your application before printing. 5. Select page setup options. Use these options to select the paper size, orientation, and scale. Note:
If you don't see these settings here, check for them in your application before printing. For example, you may be able to open the File menu and select Page Setup. 6. Select any settings that are specific to the application you're using. For example, if you're printing a photo from Preview, you see the application settings shown above.
If you have any doubt in this pls click here
Jul 26, 2011 | Epson WorkForce 600 All-In-One InkJet...
I have a 3 page document which i need to copy several times how do i collate
coppy pages to certain locations as per required order.
select destination
press copy
select multiple
type the no.
Jul 04, 2011 | Panasonic Workio DP-1820E Copier
When I print a one page document, tray 1 prints on multiple papers at a time. 1 page prints on 5 pages.
If you don't have a manual, you can find one here
My guess is either on the printer or the driver. Skimming the manual, it doesn't seem that you can set the default number of pages printed per sent print job on the printer, but that is something I would look into. This is a nice office printer, perhaps the printer is set to print multiple copies of everything it is sent. You could determine if it is the printer or driver/computer by printing to it from another computer.
If it is the computer, go into the control panel and select the properties for this printer. In there, check if the number of copies is improperly set to 5. This would happen for every print job sent from this system.
Does it print 5 copies of documents sent from different programs (i.e. Web Page, Word, Excel)? Quite possibly, one time you set it to print 5 copies and that application retained that as default. In that application, rather than clicking "print" click "printer setup" and look through the settings to see if it is requesting multiple copies.
I am 95% sure one of these three solutions will solve your problem.
May 05, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Printing too many pages
try this touch add functions key then printer settings one option should be number of copies make sure it is set at 1
Jan 21, 2009 | Canon imageRUNNER 5000 Copier
Hp LaserJet 1320 will not print multiple copies
This problem is caused by Mopier Mode being enabled by default. The idea of Mopier Mode is to minimise computer and network traffic by sending only 1 copy to a printer equiped with suitable internal memory. That stored copy is then used to produce the multiple copies. Most HP Laserjets do not have suitable internal memory and so only the one copy sent by the computer gets printed. To disable Mopier Mode:
Click Start
Click Devices and Printers
Right click your Laserjet Printer
Select Printer Properties
Click the Device Settings Tab
Scroll down to the bottom
If necessary, expand Installable Options
Click on Mopier Mode
Select Disable in the selection box that appears
Click Apply
You will now get multiple copies.
Nov 20, 2008 | HP LaserJet 1320 Printer
Will not print multiple collated two sided publications without individually sending each job
I would try changing the driver you are using. There are multiple drivers and it really sounds like that will resolve your problem.
For the drivers go to Xerox.com.
on the tool bar select Support and Drivers.
Then enter your printer number, being phaser enter phaser 7300 in the search .
Select your operating system and there will be PS and PCL drivers.
I am 99.9 percent sure the issue is in the driver.
Dec 26, 2007 | Xerox Phaser 7300DN Laser Printer
HP 4650N Will not print more than one copy of a job
make sure when printing it has all checked off in the page range box instead of pages
Aug 28, 2007 | HP LaserJet 4650n Printer
Using Job Accounting with Excel
Try unticking the collate box on the print window. this can cause 50 jobs to be sent rather than 50 copies of the same job.
Hope this helps
Mar 27, 2007 | Canon ImageRUNNER 3570 Copier/Printer
HP DeskJet 5550 InkJet Printer Logo
Ben Johnson
