Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Bottom of freezer/fridge only getting cold.
Amana side by side - 7 years old.
Compressor seems to be fine (although it is a bit hot) and the relay is ok.
The bottom of the freezer is blowing cold but it doesn't seem to be reaching the top of the freezer (where the ice maker is). The bottom crisper on the fridge side is also cold but not up to the top shelves. So - only the bottom of both are getting cold but nothing on the upper levels.
Not able to produce ice either. Thanks for any help!
Jamie
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Posted on Sep 28, 2008
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
Fridge and freezer not getting cold although fan is on and it sounds like the compressor is on. But has now stopped running so I unplugged. Is the compressor gone? This fridge is only 8 years old.
Most times the compressor start relay and run/start capacitor may be defective. If the fans run yet compressor gets very hot on top it may be trying to start and cannot because those mentioned components need replaced. Pull away from the wall, unplug and lets remove the lower cover that hides the compressor. If compressor is hot it just may be short cycling because it need these components=> MTB1954ARW Compressor Components
Finding the correct model number for yours will be important in order to get the right parts. On side by sides and top mounts should be able to find the correct numbers here=>
Top Freezer Side-By-Side For user manuals and literature click logo=> sea_breeze_117.jpg Product made for outside the US=> HERE Find model number's HERE If you feel like you need to test compressor click here=> Appliance 911 Sea Breeze Scroll to near bottom of page and read how to test a compressor. In most cases a new start relay and sometimes a hard start will give you fridge a few more years, Have questions? Let me know, Thanks, Sea Breeze
Mar 18, 2011 | Maytag 18.9 Cu. Ft. Top-Mount Refrigerator...
Hi. I have an Amana/Maytag Fridge. Model ABD2233DES bottom freezer. The fridge was working fine, then it seemed like the compressor or motor started to make a funny noise. Like it was working hard or...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 24, 2010 | Microwave Ovens
Came home from holidays to find thawed out fridge
first feel the compressor and see how hot it is,if its overly hot,replace the ptc/relay/overload on the compressor body as the compressor is not running at full speed and on both windings start and run
Mar 18, 2010 | Refrigerators
Amana side by side, buzzing, no fan in fridge.
that sound is the relay/overload. it is trying to start the compressor. the problem is either that relay or the compressor itself
Feb 05, 2010 | Refrigerators
Amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer not freezing and burning smell
it may be the compressor overheating it could be the relay but if the compressor is hot then you are low on freon and need to have it recharged
Jan 26, 2009 | Amana ARS2464B Side by Side Refrigerator
Fridge losing cool
If I was of assistance please vote, Thank you.
Dec 26, 2008 | Amana Refrigerators
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
796 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
