Question about JVC GZ-MG575 Camcorder
I dont understand how to use an external mic. Use of external mic.
The menu just says External mic level on or off without any further explanation.
  • 24 Answers
Your external mic needs to have a 1/8" plug. You will need to find the "Mic" input, this is generally found behind a removable or hinged plastic or rubber panel, and usually near the A/V plug connectors. When you plug in an external mic, the camera switches over to use it rather than the built-in mic. On this camcorder, you cannot set the recording level of the external mic. The camera sets the level automatically. So it is simply a plug-and-play, or plug-and-record solution.
Using an external mic allows you to reduce self-noise and handling noise. It is generally recommended for better videos. Different microphones are likely to interact in different ways with your camera and its automatic level-setting, so you should try out different microphones if you have more than one available to you.
Posted on Sep 26, 2008
Nextbook flexx 11" --how to turn off internal mic so external mic can work, or can you do that? my externl mic isnt woring
Hi, you can change this setting in the control panel, would you like me to show you how remotely?
Apr 15, 2016 | Computers & Internet
External microphone thinkpad t41
Control Panel, Sounds, look at Recording devices (depends on the OS you are using, you didn't mention, Vista, XP, 7,8?), Mic. Your Headphones jack, when in use, will cause the internal sound to disable, depending on OS the mic setup is a bit different but you should find it in sounds, recording devices.
Nov 12, 2012 | IBM ThinkPad T41 2373 Notebook
How do I record without sound on the Canon FS200?
go into the settings and switch to external mic and dont use the mic. or if you have an on off switch on the mic switch to off , its cumbersome but works. I have forgot to plug it in all the way and that too works gives you video no sound. you dont need a new camera , good luck
Aug 29, 2011 | Canon FS200 Flash Media Camcorder
I have a Macbook Air with Microsoft Word Home and Student 2008 installed on it. I use the audio recording feature on in Word to take notes in lectures, but since the internal mic was not enough to capture...
In sound system preferences when the external mic is plugged in, there is a drop down menu in the input tab that says "Use the audio port for:" make sure it says input.
Mar 22, 2011 | Apple MacBook Air
How do I switch off the audio on the Panasonic NV-GS250 so I can record video footage with no sound.
I think this camera has manual audio control.
Use the menu system and set the audio to manual then turn down the audio completely.
Another option is to place a microphone jack into the external mic socket without a mic attached. This will mute the onboard mic.
Al
Feb 11, 2011 | Panasonic NV-GS250 Mini DV Digital...
Can't get the external wireless mic to record...
This camcorder will record audio from an external STEREO mic plugged into the top connector on the right side of the unit (under the plastic cover). I find it works EXTREMELY well with the various Sony microphones traditionally sold for MD recording (I use a mid-size one: model #ECMMS907). Some microphones may have too low an audio level for these camcorders. Other microphones may not have a stereo plug, but most of the ones that do (and have a high output level) should work You simply plug in the mic. No fussing with settings should be necessary. The camcorder has an onscreen audio meter that can be enabled. I leave it on all the time, so I am sure the external mic is working (mine has an on/off switch as well as an AA battery -- so I really want to make sure!).
Mar 22, 2009 | Canon HV20 HDV Digital Camcorder
Regarding the canon hv20 camcorder. When using an external canon MIC a) How do you know the mic is working and you are not picking up sound on the internal MIC b)On connecting the external MIC an icon...
If you put the camcorder in manual mode, there is a microphone sensor that will move when sound is picked up by the external microphone. In manual you can keep everything else automatic. The off for the mic means that the built in mic is turned off when an external mic is attached.
Sep 16, 2008 | Canon HV20 HDV Digital Camcorder
Sound recording with external microphone
An instruction manual is available for download at www.canon.com
Your camera, according to the manual, has a single input for microphones, and in the internal menu, AUDIO DUB has to be set to MIC. IN. when using an add-on microphone. An MA-300 hot-shoe microphone accessory can be used, and then the input controls would be on this device, not the camera. Your camera can also record in two different audio qualities: 16-bit two channel or 12-bit four channel. If you are using an accessory you may need to select 12-bit in the internal setup menu in order to have enough channels to add on the additional microphone(s).
Finally, and hopefully not, the camera may have an internal hardware problem, and so would need to be serviced.
Nov 05, 2007 | Canon GL2 Mini DV Digital Camcorder
Game Mode
not familiar with this model but ill try try in the menu puting it on game mode then look for external input mode in the menu and turn it too dont work fix ur remote or bye a new one (be sure that the new remote will activate the game option) good luck windman
Jan 02, 2006 | Sylvania W4913LT TV
JVC GZ-MG575 Camcorder Logo
266 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
